Hi, long time reader, first time poster.
I'm using a PICAXE08M as a soft start for a DC lamp, code below. I am having a curious problem at the end of the timing cycle, when the second ramp finishes the PWM output go low briefly, long enough to cause a definate dark flash. I have found if I limit the duty cycle value to 250 the program is faultless, this however doesn't give me my desired end value (70%).
The manual says that the duty cycle shouldn't be more than 4x the period, my desired value of 280 is not, so I cannot see what I am doing wrong.
Any tips in the right direction are gratefully recieved.
Many thanks, 3buns.
Code follows:
'softstart_lamp.bas
'Kurt Nunn - 30/12/2009
'Revision 1.0
'History:
'Pinout
' +ve +-v-+ gnd
' Serial In | | Serial Out
' N/C | | LED 'timeout'
' N/C +---+ PWMOUT
symbol quickstep = b0
symbol slowstep = b1
quickramp:
'Quick Ramp 5% to 10% over 2 seconds
for quickstep = 20 to 40
pwmout 2,99,quickstep
pause 50
next quickstep
slowramp:
'Slow Ramp from 11% to 70% over 120 seconds
for slowstep = 44 to 280
pwmout 2,99,slowstep
pause 500
next slowstep
last: high 1 'Light Timeout LED
pwmout 2,99,280
goto last
end
Many thanks, 3buns.
Code follows:
'softstart_lamp.bas
'Revision 1.0
'History:
'Pinout
' +ve +-v-+ gnd
' N/C +---+ PWMOUT
quickramp:
pause 50
next quickstep
slowramp:
pause 500
next slowstep
pwmout 2,99,280
goto last
end
