Is pwmduty available for the 08M or not? It certainly works for the 08M2, and the following from Basic Commands doesn't specifically exclude the 08M.
PE 6.0.9.3 complains with, " pmduty command not supported by this chip, use pwmout! " and that is clear to me, but confusing when I'm following the documentation.
A forum search did not bring up anything.
Name:
pwmduty
Syntax:
PWMDUTY pin,duty cycles
Pin - is a constant which specifies the i/o pin to use. Note that the pwmout pin is not always a default output pin.
Duty - is a variable/constant (0-1023) which sets the PWM duty cycle. (duty cycle is the mark or 'on time' )
Description:
Alter the duty cycle after a pwmout command has been issued. On some parts the pwmduty command can be used to alter the pwm duty cycle without resetting the internal timer (as occurs with a pwmout command). A pwmout command must be issued on the appropriate pin before this command will function. See the pwmout command for more details and restrictions.
Applies To:
All (except 08, 18, 18A, 20M, 28, 28A)
See Also:
pwmouthpwmhpwmduty
Related Create:
LEDRGB LEDL293D Motor Driver
pwmduty
Syntax:
Description:
Applies To:
See Also:
pwmouthpwmhpwmduty
Related Create:
