Some of the younger members might be unaware of this tip.
When using a picaxe in a bread board it is a good idea to first put it into a IC socket. Then you can put it in and pull it out of your bread board as many times as you like without having to be worried about mutilating/bending/snaping off the legs.
If you damage the socket legs put the picaxe into another. You could put the picaxe into one socket then that socket into another. Then you would never expose the picaxe legs to stress even when changing sockets. IC sockets are cheap, especially when compared to the larger picaxe IC's.
To sperate the picaxe form the socekt carefully use a small screwdriver with a fine blade to prise them apart. Lever each end apart a little at a time. Don't ry and do it all from one end or youll will bend the legs.
