marzan
I have a 12 volt pump to ump rainwater ant near mains pressure. Fortunately for me I purchase 2 of them as I have an issue. There is a microswitch that detects the pressure and cuts out the pump. When the irrigation system is being supplied with rainwater the pump cannot remain on and so switches on and off very quickly. To fis this i have tried to add a water pressure tank. but the same thing happens. My theory is to set the pressure microswitch to a little less pressure and to build a timer circuit to leave the pump on for a pre-determined time once the first cut out is detected I have come up with this circuit using an 08M :
Have I missed anything out? If the amps of the motor are greater than the MOSFET, could I use 2 of them as I have a few of them, or would I be better using a relay?
Thanks.
Marz.
Thanks.
Marz.
