techElder
Well-known member
Am I to assume that the 20X2 has a base PULSOUT time of 5us since its base clock speed is 8 MHz? So, all changes in clock speed are base on that 8 MHz value?Syntax:
PULSOUT pin,time
Effect of Increased Clock Speed:
4MHz 10us unit 8MHz 5us unit 16MHz 2.5us unit 32MHz 1.25us unit 64MHz 0.625us unit
The docs are clear in other places, such as PAUSE, but the base time starts at the same time value as the 4 MHz setting in the case of PAUSE.
