Programming interface for multiple picaxes on a board?
Pongo
Does anyone have a good scheme for the download connection for programming multiple picaxes on a board? I'm going to have 4x 08M2's on the board, I don't mind duplicating the download circuits but I'm wondering if there's a way to simplify the switching of the PC connection. For instance maybe I can OR the serial outs and use a dip switch to select the serial in.
(I'm not using the serial in/out in the application.)
techElder
Well-known member
Seems like it would be just as easy to move a 3-pin header from one to the other if you have access to the board to move a dip switch.
techElder
Well-known member
Well, you did say "dip switch", but I wasn't thinking of outside the box! :)
How many of these do you have to do and how often? That could make a difference in the solution.
Pongo
Quantity isn't an issue, it's a personal project and nothing I'm selling. I can imagine that it initially it will need a lot of fine tuning, and I want something that can be re-programmed without opening the box. 4 DB9's would be a non preferred solution, as much as I love good old serial I hate making those cutouts so that's why I'm asking of anyone has an electronic solution.
Goeytex
I like the rotary switch solution. I have used a 7 position double pole switch before and it works like a charm. However this is a relatively large switch and is about 1.25" deep. But my box is large enough for it.
1 rotary switch + DB9 is probably actually larger than the 4 of the recommended 3.5mm audio sockets - and they are easier to machines (4 x single drill hole).
techElder
Well-known member
After much coffee and no sleep, :) Technical comes up with the most economical and practical solution that takes up the least amount of those highly desirable cubic inches.
Plug in the 1/8" cable into #1, - click program, #2 - click program, #3 - click program and lastly #4 - click program.
Pongo
I don't expect the rev-ed seal of approval, but the concept works. I breadboarded 4 x 08M's, 22K + 10K on each serin, serouts OR'd together with 4 x 1N4148's, common cathode. Identifies and programs each picaxe with only switching the serin connection. Programs run fine. So one small hole to access the rotary dip switch and I'll be in business :)
Thanks for all the suggestions. If I had a dollar for every strange cable in my box of "odd cables I think I should keep, but I'm no longer sure what they belong to" I could eat well at McDonalds all week, so I really wanted to avoid yet another custom cable or connector and was hoping someone had tried a similar combination scheme. I also don't see converting to using (cheesy IMHO) audio jacks for serial when I have a lifetime supply of DB9 cables and connectors although I could be tempted by the hole issue.
Note that with diode-mixed Serial Outs you will have problems should any output serial or debug data or if any sets the Serial Out pin high.
Pongo
Absolutely, thanks for the reminder. Although that's guaranteed by design not to be a problem in my application since I'm not otherwise using the serout pin, serout or debug, it won't work for everyone.
Janne
One solution would be to ditch the rotary switch as well, and issue disconnect commands to the picaxes. With a software "handshake" you could then reconnect the correct chip for programming. Example: During power up, each picaxe checks the serial input for 10s, and if it hears its ID-number it waits for new download instead of disconnect. Or check for incoming downloads with serrxd occasionally.
erco
A 4x3 header for manually attaching a 3-pin programming cable in 4 places would be a compact solution, accessible through a small rectangular hole in the case. If you used common center ground pins and flipped the cable, you could use a 5x2 header.
tmfkam
Now that's a solution. Simple. Brilliant. Love it.
Pongo
Can this really be done?
erco
Unimaginative, but it works the same. I've come to dislike the stereo jack & plug. On my own boards, soldering a 3-pin header right beside the chip is quicker & more compact. I put a mechanical polarizer on the cable's 3-pin connector and it's pretty foolproof to connect.
techElder
Well-known member
For what the OP asked for in #1 ...
I too use a header.
Pongo
I too use a header.
Not really, I asked for:
"Programming interface for multiple picaxes on a board?" "a way to simplify the switching of the PC connection. For instance maybe I can OR the serial outs and use a dip switch to select the serial in."
To me just swapping pin headers would the obvious non-simplified way to switch the PC connection.
Buzby
All this faffing just to program four 08's on one board :) .
Why not just use one, single, bigger, PICAXE ?.
( As an aside, I have developed a multiple PICAXE programming system, but it only works with X2 chips. )
slimplynth
(Wonders if a 4066 quad bilateral switch, with a 5th 08M chip to control the programming of the other 4 would work?) - if it did then an 18M2 with touch switches to select...
CDRIVE
It's unfortunate that your post received so little interest or responses. Since uC's excel at replacing hardware with software/firmware, IE "Decision Making", it would have been an interesting discussion.
Cheers,
Chris
