I am a new bee. I am working on my personal project using PICAXE 20X2. This is the first time I am ever exposed any kind of coding of microcontroller. After reading the manual I felt it is easy for me to program picaxe. Hence I am here.
My initial hick up was to make my computer connect to the PICAXE chip. I got over that with help from the forum.
My next step is to write the code for the project.
In my project I will be using "pause" command very offten as an timer.
This pause time is variable. My project will be product and packaged in box. Computer will not be connected. I should be able to increment or decrement this pause value through a PB connected to PICAXE as a input.
Can one some suggest how can I do this ?
How do I write a code if I will have to refer a "pause" value from a registor.
How can I write to register through a PB in increments or decrements ?
Is there a single command to reset values of all registors in the beginning of the program i.e initialisation.
Thanks in advance. I would be needing help more as I go on.
U.Moharana
U.Moharana
