Programming Editor - Fonts
bcj
The coding in the Editor (v4 thru to 5.0.7 always displays on screen in a small italic font regardless of any settings applied through the options.
Code saved to .bas is in a normal size non-italic font.
Is there a way to obtain normal (non-italic fonts and to change the size of these in the editor while programming.
This is a missing font issue on your computer. Make sure you have the Windows default fonts (courier) installed.
As a work around you can use RTF mode and select your font/size (View>Options>Editor)
bcj
We have all the standard Windows fonts installed,
Courier (VGA 10,12,15 and Truetype) Courier New and Courier PS in normal, bold, italic and bold italic.
Normal Courier is the default font in other programs - (Notepad etc) but not in the Programming Editor.
Is there no way to set the font? - A registry entry or .ini file perhaps.
bcj
OK, Have deleted and re-installed the Courier 10,12,15 (VGA) coure.fon file (which was already there) with another from a differnt source and problem seems to be resolved.
Thanks
