Which Picaxe chip?No worries
It doesn't quite solve how I'm going to get a 100 - 150 Hz square wave out of the PWM pin, but it all helps to fine-tune an already very good piece of software.
cheers
barney
Well, if you're going to use another chip,I'm temporarily using a 40x1 at 8MHz, I can get it down to about 500 Hz pwm and then it says "no more".
I'm going to be using the square wave (at about 100 - 150 Hz) to drive the backplane of an LCD, not sure if they would like being kicked at 500 Hz.
The alternative of course is the good ol', ubiquitous 555 in astable mode
