sierra_uniform
I changed an older program for a 08m to use it on a 08m2 by changing the notation of the used pins.
Old version was:
symbol led = 1
symbol taster = pin3
button 3,1,0,0,b3,1,<address>
New version is:
symbol led = C.1
symbol taster = pinC.3
button C.3,1,0,0,b3,1,<address>
Downloading the new program to a 08m it works very well. Downloading it to a 08m2 (using the same hardware) it doesn’t work. The correct program flow after connecting the battery should be the following:
1. Set servo signal to 96,
2. led blinking 5 times,
3. led constant on and waiting for input via push-button.
Using a 08m2 the led is blinking in an endless loop and the servo shortly jitters in the frequency of blinking. What could be the reason???
Old version was:
symbol led = 1
New version is:
symbol led = C.1
