Hello All,
I'm new to this forum, so please excuse any potential errors in protocol.
I'm having two problems with a color sensing project. Both programs are standrd, already tried and true programs for the PicAxe. I'm running Windows 7 on my PC, and the Color sensor is from Taos as purchased through Parallax. I'm also using the Parallax cable and adaptor to a Kiwi Patch Board. I'm using an 8M2, running off of a 6 VDC battery pack. The program loads into the PicAxe, and the 2 LEDs on the color sensor flash once per second (assume while its taking a reading), but the information on the serial terminal is jibberish. I've tried all possibile baud settings, including the special one for the USB to serial cable (PixAxe part 027).
‘ PICAXE-08M2 input/output pins
symbol LED = 0 ‘ Color sensor white LEDs (output 0)
symbol S2 = 1 ‘ Color sensor select S2 (output 1)
symbol ser = 2 ‘ Servo or serial LCD (output 2)
symbol CSI = 3 ‘ Color sensor pulse (input 3)
symbol S3 = 4 ‘ Color sensor select S3 (output 4)
‘ Variables
symbol red_value = w4 ‘ Color sensor red content
symbol blue_value = w5 ‘ Color sensor blue content
symbol green_value = w6 ‘ Color sensor green content
‘ Remember w4-w6 uses b8-b13!
‘ scan and display every second
gosub color ‘ scan the colour
sertxd ("Red =", 9, #red_value, 9)
sertxd ("Blue =", 9, #blue_value, 9)
sertxd ("Green =", 9, #green_value, CR, LF)
‘ sub to scan colors
color:
high LED ‘ LED on
low S2 ‘ read red into w4
low S3
count 3, 50, red_value
high S3 ‘ read blue into w5
count 3, 50, blue_value
high S2 ‘ read green into w6
count 3, 50, green_value
low LED ‘ LED off
My second problem is another PicAxe color program where I want to hook up a serial LCD to the project. The problem is a syntax error that I can't get by. The program is below:
‘ PICAXE-08M input/output pins
symbol LED = 0 ‘ Colour sensor white LEDs (output 0)
symbol S2 = 1 ‘ Colour sensor select S2 (output 1)
symbol CSI = 3 ‘ Colour sensor pulse (input 3)
symbol S3 = 4 ‘ Colour sensor select S3 (output 4)
‘ Variables
serout 2,N2400,(254,128"R=",#red_value, " ")
serout 2,N2400,(254,136"B=",#blue_value, " ")
serout 2,N2400,(254,192"G=",#green_value, " ")
‘ sub to scan colours
color:
high LED ‘ LED on
low S3
low LED ‘ LED off
The Syn tax error is a compile error: serout 2,N2400,(254,128"R=",#red_value, " ")
The "^" symbol is below the comma just before the # symbol
Error: Syntax error in this line!
Any help for either problem would be appreciated.
Sincerely,
Fierojo
‘ Variables
color:
high LED ‘ LED on
low S3
low LED ‘ LED off
‘ Variables
color:
high LED ‘ LED on
low S3
low LED ‘ LED off
Sincerely,
Fierojo
