Problem to simulate
kristercnc
Hello,
I have a program that uses one temperature and one input as the input values. In simulation I have to write the temperature every cycle. That makes it impossible to also set (click on ) an input. Is there any way that I can set an input permanently on ( no need to click on it every cycle). The same problem comes if I need several inputs on at the same time.
nick12ab
There's no proper way to do this, but there is a workaround.
  1. Position the Digital Panel somewhere so that it is behind the Start Menu when you open the Start Menu
  2. Hold the mouse button down on the input that you want to set high
  3. Press the Windows key on the keyboard so that the Start Menu appears
  4. Release the mouse button
  5. Press the Windows key again to make the Start Menu disappear
The input should now stay high when you do other things in Logicator.
A certain competitor which is mostly inferior to PICAXE uses the shift key to make an input stay high when it it clicked. Rev-Ed should implement this in Logicator.
