Problem of Jittering in "reserveW0"?
Gramps
Why does the code jitter ? Especially in:
reserveW0 = w0 ; b1:b0
Gramps
#Picaxe 28X2
#No_Data
#No_Table
Symbol DESIRED_POT      = 17 ; C.5 = ADC17
Symbol FEEDBACK_POT     =  4 ; C.3 = ADC4
; N = Vin * 1023 / Vpsu, Vpsu = 4.83V
Symbol FEEDBACK_TOP     = 830 ; 3.92V
Symbol FEEDBACK_MID     = 512 ; 2.47V
Symbol FEEDBACK_BOT     = 216 ; 1.02V
Symbol FEEDBACK_TOP_GAP = FEEDBACK_TOP - FEEDBACK_MID
Symbol FEEDBACK_BOT_GAP = FEEDBACK_MID - FEEDBACK_BOT
Symbol  DIRECTION       = C.4
#Define CLOCKWISE       High DIRECTION
#Define ANTICLOCKWISE   Low  DIRECTION
Symbol MOTOR            = C.2
Symbol MOTOR_PERIOD     = 100
Symbol MAX_SPEED        = 300
Symbol PAUSE_MS         =2000 ; Millisecond delay when target reached
Symbol reserveW0        = w0 ; b1:b0
Symbol desiredPosition  = w1 ; b3:b2
Symbol currentPosition  = w2 ; b5:b4
Symbol speed            = w3 ; b7:b6
  Gosub ReadDesiredPostion
  Gosub ReadCurrentPosition
  Select Case desiredPosition
    Case  > currentPosition : Gosub TurnClockwise
    Case  < currentPosition : Gosub TurnAntiClockwise
    Else                    : Gosub StopTurning
  End Select
ReadDesiredPostion:
  ReadAdc10 DESIRED_POT, w0
  debug
CalcDesiredPosition:
  desiredPosition = w0
ReadCurrentPosition:
  ReadAdc10 FEEDBACK_POT, w0
  debug
CalcCurrentPosition:
  If w0 >= FEEDBACK_MID Then
    w0 = w0 - FEEDBACK_MID
    w0 = w0 * 128 / FEEDBACK_TOP_GAP * 4 Max 511
    w0 = w0 + 512
  Else
    w0 = FEEDBACK_MID - w0
    w0 = w0 * 128 / FEEDBACK_BOT_GAP * 4 Max 512
    w0 = 512 - w0
  currentPosition = w0
TurnClockwise:
    If speed = 0 Then
      speed = MAX_SPEED
      CLOCKWISE
      PwmOut MOTOR, MOTOR_PERIOD, speed
    Else
      CLOCKWISE
      PwmDuty MOTOR, speed
  Loop Until currentPosition >= desiredPosition
  Gosub StopTurning
TurnAntiClockwise:
    If speed = 0 Then
      speed = MAX_SPEED
      ANTICLOCKWISE
    Else
      ANTICLOCKWISE
  Loop Until currentPosition <= desiredPosition
  Gosub StopTurning
StopTurning:
  PwmOut MOTOR, MOTOR_PERIOD, 0
  If speed <> 0 Then
    Pause PAUSE_MS
  speed = 0
[code]
Debug can cause unexpected delays because of the time it takes to execute. Replace all with appropriate SERTXDs. Then if there's still a problem, report in more detail, including gear being controlled and what the intention is for maths in the program (comments are good).
Gramps
Yes we will try that and report back.
correction. Hippies original code contained all the necessary scrtxd's plus a whole lot more code to illustrate different simulations. The code posted in this thread is only a portion of his work.
Gramps asks your forgiveness
Sertxds also slow down execution to a crawl. Comment them all out to run at full speed.
Seems like an odd naming convention IMHO. The variable name "reserveW0" is never used other than to make it equal to word variable W0. WO is used directly multiple times as a disposable value in subsequent ADC10 calculations.
My take is it's a convention just to alert a future programmer that W0 (comprised of B0 and B1) is used in the program and to avoid using it and overwriting it. Likely good practice in demo code for budding programmers to study & emulate.
My personal preference is to not use variable names. I just use B0, B1, W2 etc and keep track of variables used myself. Keeps my programs shorter and (for me anyway) more readable. But then again I'm not a real programmer. :)
Aries
Those of us (are there any others?) who started life as Univac assembler programmers, used registers (A0-15, X0-X15, R0-R15) to manipulate values, and memory locations (nameable) to store them. Like Erco, I have continued to use the same principle, using b0-bxx, w0-wxx etc as they are, and using other RAM memory locations by name via SYMBOLs. I do appreciate that there can be virtue in using aliases for the w and b variables, but for complex programs they have to be reused anyway.
Besides, I use bit0-bit7 (which comprise b0) a lot for flags within programs, so I avoid using b0, b1 and w0 (comprised of b0+B1) since they all overlap.
