Hi there,
I've done some basic picaxe circuits before and i just love these little chips. I normally use the 08m2 for it's size and low price, i've got a ton of these to play with![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
I now need a simple circuit like a wired with 2 or 3 buttons.
each button connected to an input on the 08M2.
That part is simple.. what i cannot figure out is, i what the push of any button to function as a power button too. that is: the circuit is OFF, and when you push a button, the circuit gets power AND the input connected to that switch changes state to ON.
If it was just one button, i could just make it a power button and had the input already closed.
if i use DPDT switches i could also close the input and close the POWER circuits with the same push.
But i want to use small SPST switches..
How do i do this?
Thank you!![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
How do i do this?
Thank you!
