I have a circuit that has me scratching my head.
This is for a special mix in radio control.
The 2 channels are controlled by an analog voltage using pots as voltage dividers from 0-5v.
When pot A is between 0 and 2v, I want to add 3v and feed that to the second channel in place of the normal signal from B (i.e., 1v on A feeds 4v to B, ov on A feeds 3v to B, 2v on A feeds 5v to B)
When pot A is between 3v and 5v, I want to subtract 3v and feed that to the second channel in place of the normal signal from B (i.e., 3v on A feeds 0v to B, 4v on A feeds 1v to B, 5v on A feeds 2v to B)
Between 2v and 3v on A, the voltage on Pot B is passed through, regardless of its value.
Been cogitating using an I2c DAC, but then it occurs to me there may be simpler electronics to accomplish the same thing, but that requires a minimum of an 18x, I believe.
Then thought about using an 08M with an ADC read, some figuring, and a PWM out with a capaciot0or to smooth out the signal (thoug I have never done this, and am not sure how sensitive the inputs on the encoder board are to the fluctuations of a PWM simulated analog voltage).
Am I missing some easy solution by overthinking this thing?
Any thoughts/suggestions are welcome.
Cheers,
Wreno
ps - Yes, this is the flip side of the Fire Control Assistant project for Radio Control Model Warship Combat, which kind of does the same thing downstream of the receiver, based on the servo pulses (reading and modifying them), but this attacks the problem upstream of the transmitter encoder for those who want to put the circuit in one transmitter rather than build, say, 5 for 5 different ships. Or flip a switch on the TX to disable it.
ww
Cheers,
Wreno
ww
