pjrebordao
Inside PE6, I simulated running the following piece of code for a 20X2.
While performing the IF, both the first and last sections of code were executed... It should have been only the first one.
symbol IX_BIN_SIZE = 15 ' size of each vector
symbol IX_MAP_X = 12
symbol IX_TOP = 121 ' last address in EEPROM
' vars for holding values read from sensors
symbol RAW_MAP = w3
' vars for holding sensor values after map_int
symbol MAP_MAP = b39
symbol I = b22 ' generic byte counter for loops, etc
symbol Z = w5
symbol X1 = w6
symbol X2 = w7
symbol Y1 = w8
symbol Y2 = w9
'macro map_interpolate(index, in_var, out_var) ' defined as a macro to avoid gosub time overhead
' map_interpolate (map_int)
' linear interpolation according to Y = Y1 + (Y2-Y1)*((X-X1)/(X2-X1))
' problemas com tamanho (byte / word ?)
' search for the right bin
' on exit, ptr will contain the upper limit of the bin found
data (0,0,0,0,0,0,0,0,0,0,0,0)
' MAP raw data (x-bins)
data (10,12,14,16,20,24,28,32,34,36,38,38,40,40,40)
' MAP time data (y)
data (15,15,17,13,11,11,9,9,7,7,5,5,8,8,8)
' TPS raw data (x-bins)
data (0,0,0,0,0,0,0,0,0,0,0,0,0,0,0)
' TPS time data (y)
' TMP raw data (x-bins)
' TMP time data (y)
' IDLE PWM data (y)- uses the TMP x-bins
' several configuration variables (5)
data (0,0,0,0,0)
let ptr = 0
for I = 0 to IX_TOP
read I, @ptrinc
next I
let RAW_MAP = 42
let I = 0
let ptr = IX_MAP_X
do while RAW_MAP > @ptr and I < IX_BIN_SIZE
inc I
inc ptr
' detect if lower or upper bound / bin
' *** simplificar
' e se RAW_MAP = @ptr and I > 0 ?
if I = IX_BIN_SIZE then
let ptr = ptr + IX_BIN_SIZE - 1
let MAP_MAP = @ptr
elseif I = 0 or RAW_MAP = @ptr then
let MAP_MAP = @ptr
let X2 = @ptr
dec ptr
let X1 = @ptr
let MAP_MAP = RAW_MAP - X1
let Z = X2 - X1
let MAP_MAP = MAP_MAP * 100 / Z
let Y1 = @ptr
inc ptr
let Y2 = @ptr
if Y2 > Y1 then
let MAP_MAP = Y2 - Y1 * MAP_MAP / 100 + Y1
let MAP_MAP = Y1 - Y2 * MAP_MAP / 100 + Y2
end
