i have a problem using a 28x, i am using the readadc10 command and i am using the picaxe28 starter kit for programming, i find it easier than using the pic programmer.. using version 4.1.15 upgrading as we speak
code..
if porta pin2 =1 then ttripa
if porta pin2 =0 and thermal =1 then ttripa
if porta pin2 =0 and thermal =0 then testmode
code works fine if last line is true, goes to testmode but i cannot get it to go to ttripa correctly...thermal is just an input pin on portb
i have considered if thermal = 1 then just goto ttripa..
if thermal =1 then thermal ttripa
if porta pin2 =0 and thermal=0 then testmode
ttrips works fine like this but testmode will not, please note i do use the readadc10 command in testmode
All i am using porta for is to determine testmodes, i have more than one using the thermal and port a command i was hoping to have 2 test function for setting up and safety then lastly a complete run situation when everything is checked and calibrated and running ok
code..
