I have an issue with an 08m where if I disconnect a wire from the breadboard to input pin 2 of the chip, it seems to register that the pin has gone high. This wire is connected to a push switch which is connected to Vcc. When the wire is connected to the switch it works perfectely, but if i pull the wire out the pin reads high? Isn't this akin to just pushing the switch?
When high my code then pulses a buzzer. Sometimes on the wire disconnect the buzzer pulses once, other times it may pulse several times or indefinitely (my ears haven't allowed it to go that far yet!)
I am using an experimenter board which utilises pull a pull down resister array for all inputs.
Anyone know why this is happening?
