I've got hold of a sabertooth 2x32A dual H bridge.
I want to use it on a remotely controlled robot, I have built and tested the wireless comms, so I'm not using an RC model remote control system.
It can be controlled using servo inputs so the servo/ servopos command will work but I would like to be able to use serial.
On page 24 of the Sabertooth manual, see the link below it shows the use of the following after each command- \r\n
The manual talks about it being the enter command.
I would like to see a section of code that someone has used with a PICAXE interfacing with a Sabertooth because I don't want to have to get another Sabertooth or PICAXE chip if I screw it up.
There are Arduino examples but I'm not familiar enough with the Arduino code to 100% not screw it up
Another issue I can see arising is the effect of servo jitter on the sabertooth, if anyone has use a Sabertooth 2 x 32A with a PICAXE in serial, legacy serial or RC servo mode, can I have a look at you code to drive it.
manual- https://www.dimensionengineering.com/datasheets/Sabertooth2x32.pdf
Any assistance is appreciated
