danners430
Afternoon folks,
I'm trying to check the syntax on what I would call a reasonably simple program - quite literally all it does is load a set of data into the table memory of a 20M2. However, when I hit Check Syntax, Windows throws up an error, saying PICAXE PreProcessor has stopped working.
I've got a copy of Visual Studio on my laptop, so I opened it to get the error code, which is as follows:
Unhandled exception at 0x0040896e in picaxepp.exe: 0xC0000005: Access violation reading location 0x2c34202c.
My program is as follows:
All it does is load a basic ASCII character set, in 5x8 character map format, into the table memory, for use later when driving LED dot matrix displays (through a driver)... any clues anyone?
Table 0, (0, 0, 0, 0, 0, 62, 72, 136, 72, 62, 130, 254, 146, 146, 108, 124, 130, 130, 130, 68, 130, 254, 130, 130, 124, 254, 146, 146, 146, 130, 254, 144, 144, 144, 128, 124, 130, 130, 146, 94, 254, 16, 16, 16, 254, 0, 130, 254, 130, 0, 4, 2, 130, 252, 128, 254, 16, 40, 68, 130, 254, 2, 2, 2, 2, 254, 64, 48, 64, 254, 254, 32, 16, 8, 254, 124, 130, 130, 130, 124, 254, 144, 144, 144, 96, 124, 130, 138, 132, 122, 254, 144, 152, 148, 98, 100, 146, 146, 146, 76, 128, 128, 254, 128, 128, 252, 2, 2, 2, 252, 248, 4, 2, 4, 248, 252, 2, 28, 2, 252, 198, 40, 16, 40, 198, 224, 16, 14, 16, 224, 134, 138, 146, 162, 194, 4, 42, 42, 42, 30, 254, 18, 34, 34, 28, 28, 34, 34, 34, 4, 28, 34, 34, 18, 254, 28, 42, 42, 42, 24, 8, 63, 72, 64, 32, 8, 21, 21, 21, 30, 254, 16, 32, 32, 30, 0, 18, 190, 2, 0, 4, 2, 34, 188, 0, 0, 254, 8, 20, 34, 0, 130, 254, 2, 0, 62, 32, 30, 32, 30, 62, 16, 32, 32, 30, 28, 34, 34, 34, 28, 31, 20, 20, 20, 8, 8, 20, 20, 12, 31, 62, 16, 32, 32, 16, 18, 42, 42, 42, 4, 32, 252, 34, 2, 4, 60, 2, 2, 4, 62, 56, 4, 2, 4, 56, 60, 2, 12, 2, 60, 34, 20, 8, 20, 34, 48, 10, 10, 10, 60, 34, 38, 42, 50, 34, 124, 138, 146, 162, 124, 0, 66, 254, 2, 0, 70, 138, 146, 146, 98, 68, 130, 146, 146, 108, 24, 40, 72, 254, 8, 228, 162, 162, 162, 156, 60, 82, 146, 146, 12, 128, 142, 144, 160, 192, 108, 146, 146, 146, 108, 96, 146, 146, 148, 120, 0, 6, 6, 0, 0, 0, 5, 6, 0, 0, 128, 64, 160, 64, 32, 32, 64, 160, 64, 128, 0, 128, 64, 32, 0, 0, 32, 64, 128, 0, 0, 224, 0, 224, 0, 0, 0, 192, 0, 0, 64, 128, 138, 144, 96, 0, 0, 253, 0, 0, 76, 146, 158, 130, 124, 2, 2, 2, 2, 2, 40, 16, 124, 16, 40, 40, 254, 40, 254, 40, 18, 42, 254, 42, 4, 196, 200, 16, 38, 70, 108, 146, 170, 132, 10, 0, 56, 68, 130, 0, 0, 130, 68, 56, 0, 16, 16, 124, 16, 16, 16, 16, 16, 16, 16, 4, 8, 16, 32, 64, 0, 108, 108, 0, 0, 0, 106, 108, 0, 0, 16, 40, 68, 130, 0, 40, 40, 40, 40, 40, 0, 130, 68, 40, 16, 0, 254, 130, 130, 0, 64, 32, 16, 8, 4, 0, 130, 130, 254, 0, 32, 64, 128, 64, 32, 0, 16, 108, 130, 0, 0, 0, 255, 0, 0, 0, 108, 130, 16, 0, 16, 32, 32, 16, 32)
