I have a EL wire inverter with is "normally" powered by two-AA batteries (3v), but works perfectly well with a 5v power source (only the wire glows slightly brighter). There is a momentary switch on the inverter to switch modes as follows:
power on: inverter OFF
press once: inverter ON - CONSTANT
press again: inverter ON - FAST STROBE
press again: inverter ON - SLOW STROBE
press again: inverter OFF
(repeat)
I checked the switch leads on the board and I measured 5v. I did not have a scope to see what happens when I press the button.
My question is how to use an output pin of the picaxe to 'safely' simulate the button press? A transistor switch at the output?
It's probably very simple, but I am new to the picaxe and this forum has been very helpful
Thanks.
(repeat)
Thanks.
