AllanBertelsen
I got one 18X serving as master and 08M serving as slave.
Now they work fine talking serin/serout via two lines. I even managed them to use interrupt to trigger communication so they won't have to spent time just listening for serin.
Then I realised, that I need 4 I/O's on the 08M in addition to the communication lines.
I got a spare line on the wire between master and slave. But I can't use this for the fourth I/O on the slave side. 08M has to use all 4 I/O's directly. I was thinking on the possibility to use only on pin for I/O on 08M as they can change direction.
I got a quad NAND gate. I could maybe use the spare line to control direction as a read/write signal.
I was thinking of something like this:
<code><pre><font size=2 face='Courier'>
____
serin / |----------.
--------o| | |
\____|-----. |
| |---- I/O on 08M
serout ____ | |
| |o---------.
.---|____/ |
| ____ |
R/W | .-| \ |
-----.-| | |o----.
.-|____/
</font></pre></code>
Do you have any suggestions?
____
--------o| | |
\____|-----. |
| |---- I/O on 08M
serout ____ | |
| |o---------.
.---|____/ |
| ____ |
R/W | .-| \ |
-----.-| | |o----.
.-|____/
