Buzby
I'm looking at using the PICAXE 18X running at 4MHz to monitor two digital inputs which are repeatedly changing state every 8 seconds, at approximately the same time as each other within a 2 sec window. ( i.e. one might change at 7.65 sec and the other at 9.20 sec, then again at 17.30 and 15.85, a bit like times on a stopwatch for two runners.)
The PICAXE will record the timestamp at which each input changes, then send these values out over a serial port. I know this task is fairly simple to code, but how fast will a PICAXE be able to this ?.
The time difference between the inputs could be from zero to 2 seconds , and I need results to a resolution of 5ms or better.
Am I on a hiding to nothing if I try to use a PICAXE for this task ?.
( The reason I looked at PICAXE is becase the project board is exactly what I need, no having to build any extra gubbins. I need 12 of these, so the less hardware mods the better !.)
