I own a commercial garden water sprinkler and would like to make a replica controller using a PICAXE.
This is how the existing machine works:-
On/Off switch.
Switch to On, for programming press OK.
Press Time button. Red LED flashes, select hour. This is done using what seems to be a 24 position rotary switch. Turn the switch to the hour you are at – e.g. 15 (3pm). Press OK
Press Start Time. Next, Start Time LED flashes. Select from 1 to 24, turn switch accordingly to 15 (3 pm for example) Press OK.
Press Frequency. Next is the choice of 8, 12, 24, hours, and 2, 3, 7 days. Select whichever. Press OK.
Press Run Time. Next is the choice 1, 3, 5, 7, minutes with carious choices up to 180 minutes. Res LED flashes. Press OK.
And from this point on the machine will faithfully work for about one year on a standard 9 volt battery.
More technical detail.
The water valve unit is a latching type and at the required On time the electronics emit a momentary pulse which energises a solenoid thus releasing pressure on a diaphragm and allowing water to flow. On the connecting plug between the detachable electronic controller and the body of the valve - which includes the solenoid coil - I have discovered that the centre pin is at negative whilst the outer contact is at positive and the pulse voltage is at about 3 volts. Measured by a fast eye on an analogue meter.
Whilst water is flowing no power is supplied to the solenoid.
To switch off the water supply a second pulse is sent to the solenoid but this time the polarity arrangements are a reverse of the above.
The solenoid coil resistance is 34 Ohms.
After viewing this website for many years and obtaining much satisfaction from the good advice given, plus the success of projects especially those with problems that finally resolve themselves, I think I shall give it ago.
As for myself I am British, 62 going on 63 years, self taught in basic electronics, technically minded and live in Hong Kong. I have my own renewable energy system in my home using automatic sun tracking photo-voltaic cells. Electronics control and protect the battery storage system, with a suitable dump load arrangement. I also have a self made solar hot water system which has been in operation for about five years and has now paid for itself. I am keenly aware of your regular advice about power supplies for Picaxes, and interfacing with LCD’s, 7 segment displays, post a photograph, post your code and post a circuit. My programming experience goes back to Apple II Plus days and building the software and hardware to flash my Christmas tree lights.
I can follow basic electronic circuits and have experience drawing my own circuit boards using PCB Express.
After searching the Internet and studying all my circuit books the only thing I cannot fathom out is how to achieve polarity switching without the use of relays. I believe the change of polarity is something to do with push/pull from the solenoid.
If I manage to reach this goal I plan a later circuit using a 12 volt DC supply from my home renewable energy system and a solenoid that requires energizing whilst water is flowing. The reason for this is that my RE system produces too much energy for my needs and I keep looking for ways to use it.
To conclude, can I use a 08M for my proposed project? Displays are not required and LED indicators are fine.
David
On/Off switch.
David
