I do some general electronics consultancy work for a company that sells electronics kits to schools in Australia.
One of the kits they sell is a Robot Arm with Controller. They recently used the last of their old Picaxe-40 chips and purchased replacements that are now Picaxe-40X2.
I did not design this kit and the person who did is no longer contactable.
I have designed a number of Picaxe projects in the past, but they were for Picaxe 08M2 and 14M2.
I was asked to program a number of chips for them. When I went to program them, I discovered the original program would no longer pass the syntax check. I discovered that the program no longer worked with the 40X2. I looked around to see how the coding had changed, made changes I thought would work, but without success. I tried using AI, again without success.
After spending a lot of time without success, I spoke to the owner of the business and suggested he advertise on this forum to have the program updated to suit the Picaxe-40X2. The new 40X2’s are PIC18F45K22 chips.
If you are interested contact me and I can send you the construction and programming notes and will also put you in contact with the owner, with who you can discuss remuneration for your services.
