hi, i am simulating a program that uses both sets of outputs legs 11-18 portc and 21-28 normal outputs that the picaxe28x offers but i am also using the inputs from leg 11-14 and i need to prees these buttons to test if my programm fullys works but when i simulate it the portc outputs runs over the buttons and you cannot press them i am using th programming editor v5.1.3 do i need to use program lines to make them back into inputs then check to see if the button has been pressed and press it or can you only have them one or the other in one program thanks
