I think my 08m2 chip is bad and made this little test routine to test each output. I don't find anything that says the 08m2 pin 7 / C.0 does not output high/low. C.0 is not responding using a LED and 330 ohm resistor to ground like the other 3 pins in this routing. Specs say C.0 is serial out (out/hserout/DAC) Correct ? Thanks, Bill
high c.0
high c.1
high c.2
high c.4
low c.0
low c.1
low c.2
low c.4
