Davidewjones
Hi all
This is my first project with microcontrollers so I thought I would start off with something easy an electronic lock for the old work shed.I have built the Piclock circuit and downloaded the code for the 18m2 chip and everything seemed to work fine, I could reprogramme the lock code from 9351 and this is when I found out that you couldnt use a 0 ZERO in the code. 1 to 9 all ok but a zero in any of the 4 digits won't work.Its not the keypad because by swapping keypad rows 3 + 4 ie B2 and B3 keys 8 + 9 become 0 and # which work ok, so as far as I can work out it seems to be something to do with zero in the code and I havent a clue .Hope someone out there can help
Thanks Dave
#picaxe 18m2
;output 7 - FET to drive solenoid bolt
;output 6 - piezo sounder
;output 4,5 - bicolour LED
;output 3 - row 4
;output 2 - row 3
;output 1 - row 2
;output 0 - row 1
;input 0 - column 1
;input 1 - column 2
;input 2 - column 3
symbol key_pos = b0 ; number of keys pressed
symbol key_value = b1 ; value of key pressed
; *** reset position to zero ***
init:
let dirsB = 255
let key_pos = 0
; *** now scan each row in turn ***
; *** by setting only 1 row (and LED) high ***
; *** if a switch is hit jump call score sub below ***
scan:
let key_value = 0
let pinsB = %00010001
gosub key_test
let key_value = 3
let pinsB = %00010010
gosub key_test
let key_value = 6
let pinsB = %00010100
gosub key_test
let key_value = 9
let pinsB = %00011000
gosub key_test
goto scan
; *** Score sub procedure. ***
; *** return straight away if no key pressed ***
key_test:
if pinC.0 = 1 then add1
if pinC.1 = 1 then add2
if pinC.2 = 1 then add3
; *** key value will already be 0, 3, 6, or 9 ***
; *** so add 1, 2 or 3 to this value ***
add3: let key_value = key_value + 1
add2: let key_value = key_value + 1
add1: let key_value = key_value + 1
; *** Make a beep ***
sound B.6,(60,50)
; *** Now increase position counter by 1 ***
; *** and test for 1st, 2nd 3rd or 4th push ***
let key_pos = key_pos + 1
if key_pos = 1 then test1
if key_pos = 2 then test2
if key_pos = 3 then test3
; if key_pos = 4 then test4
; *** Now test the value for each position individually ***
; *** If value is wrong restart, if correct loop until ***
; *** fourth go. If fourth is correct open lock! ***
; *** Key code is set to 9-3-5-1 ***
test4:
if key_value = 1 then open
goto reset1
test3:
if key_value = 5 then continue
goto reset1
test2:
if key_value = 3 then continue
goto reset1
test1:
if key_value = 9 then continue
goto reset1
; *** Got here so open lock and set LED green for 5 sec ***
open: let pinsB = %10100000
wait 5
goto reset1
; *** Not correct value so reset position counter then return ***
reset1:
let key_pos = 0
; *** Okay so continue by returning back to main loop ***
continue:
Thanks Dave
#picaxe 18m2
;output 3 - row 4
;output 2 - row 3
;output 1 - row 2
;output 0 - row 1
;input 0 - column 1
;input 1 - column 2
;input 2 - column 3
init:
let dirsB = 255
let key_pos = 0
scan:
let key_value = 0
gosub key_test
let key_value = 3
gosub key_test
let key_value = 6
gosub key_test
let key_value = 9
gosub key_test
goto scan
key_test:
sound B.6,(60,50)
test4:
goto reset1
test3:
goto reset1
test2:
goto reset1
test1:
goto reset1
wait 5
goto reset1
reset1:
let key_pos = 0
continue:
