An older post in the Misc completed project area..I posted there but am not sure these areas are very active..
I am trying to set up an web cam that I can control via PICAXE.
I have the Pan/Tilt servos and have set them up on a 08/M as described in the post. I am using an 18X to send commands to the 08 but am not getting consistent results. I used the code that was posted in the thread and it seems to be working.. Can someone give me a little sample code that I can use to test this setup?
The discussion talked about sending key strokes to the 08. I am not sure how to send the commands from the editor?
Thanks.
Thanks.
