Nice. I learned something new today. It probably takes up the same memory as discrete high commands, but makes for a tidier code read. Thanks westaust55!HIGH B.0, B.5, B.6, C.3
TOGGLE B.1, B.3, C.5
I did not know either. The documentation is only reporting its action for a single bit. Thanks westaust55.... can change the state... of several pins
Actually, both the PDF and on-line manuals do say one or more pins:I did not know either. The documentation is only reporting its action for a single bit. Thanks westaust55.?
I missed that!... one or more pins:
Because a number of people have thought the M2's offer I2C slave capability when they do not I have added that to the list on the page.In http://www.picaxe.com/What-is-PICAXE/PICAXE-Chip-Sizes/, instead of only I2C, could it be added the master/slave capability of each chip?
Pretty much what it states in the online version:I missed that!
A suggestion for the doc : "TOGGLE pin_1,pin_2,pin_3,... / Pin_x - is a variable/constant which specifies the i/o pin to use."
And a code example illustrating this case...
