Update: I have confirmed on another board that I can see the oscillator on Pins 9/10. So, this one has a problem which is quite suspicious.
On a 28x part with an external crystal should you be able to see this with a scope on pin 9 or 10?
My chip is acting strange. I won't communicate with another chip. I see the clock pin go high a couple of times then just die so I am curious if my crystal is bad. I can not see any activity on pins 9 or 10 that the external crystal is connected to.
