OPL-Transmitter.C
#1
/* RASPBERRY PI One-Page LoRa TRANSMITTER
*  AI Ra-01_V1.0 Semtech SX1278
*  LoRa            Pi
*  3.3V         3.3V    Red
*  GND            GND        Black
*  SCK            SCLK    Yellow
*  MOSI            MOSI    Green
*  MISO            MISO    Orange
*  NSS            CE0    White
*  RESET        #18    Brown
*  DIO0    ------1k------- #24    Grey IRQ pulled down + 1k current limiter
*  Pi3.3V--button--1k--> #17    STOP button pulled DOWN + 1k current limiter
#include <bcm2835.h>
#include <stdio.h>
const int reset = 18;
const int irq = 24;
const int button = 17;
void SXSetup(void)
    char buf[2];
    bcm2835_gpio_write(reset,LOW);              // reset low  100us
    delayMicroseconds(100);
    bcm2835_gpio_write(reset,HIGH);
    delay(10);                                // time to reset,  minimum 5ms
    buf[0] = 0x81; buf[1] = 0x00;               // sleep mode
    bcm2835_spi_transfern(buf, sizeof(buf));
    buf[0] = 0x81; buf[1] = 0x88;               // LoRa, low frequency mode
    buf[0] = 0x89; buf[1] = 0xF3;               // PA_BOOST
    buf[0] = 0x91; buf[1] = 0xF7;               // Setup for TX_Done interrupt
void clear_LoRa_interrupts(void)
    char buf[2];
    buf[0] = 0x92; buf[1] = 0xFF;
void send(void)
    char buf[2];
    char data = 0;
    while(!bcm2835_gpio_lev(button))         // while button not pressed
        buf[0] = 0x81; buf[1] = 0x09;            // standby to set up packet
        buf[0] = 0x8D; buf[1] = 0x80;            // Transmitter base address
        bcm2835_spi_transfern(buf, sizeof(buf)); // Set SPI fifo pointer
        buf[0] = 0x80; buf[1] = data;
        bcm2835_spi_transfern(buf, sizeof(buf)); // Write packet to fifo
        buf[0] = 0x81; buf[1] = 0x8B;
        bcm2835_spi_transfern(buf, sizeof(buf)); // TX on, LF mode (send)
        delay(100);
        buf[0] = 0x12; buf[1] = 0x00;
        bcm2835_spi_transfern(buf, sizeof(buf)); // Get RegIrqFlags
        if (buf[1])                              // If RegIrqFlags != 0 then TXDone
            printf("Sent %d \n",data);       // so byte has been sent
            clear_LoRa_interrupts();
        bcm2835_spi_transfern(buf, sizeof(buf)); // TX and RX to sleep, clear fifo
        delay(900);                    // Wait a ~sec before sending next byte
        if (data<10){
            data++;
            data = 0;
int main(int argc, char **argv)
    if (!bcm2835_init())
            printf("bcm2835_init failed. Root?\n");
            return 1;
    if (!bcm2835_spi_begin())
            printf("bcm2835_spi_begin failed. Root?\n");
            return 1;
    bcm2835_gpio_fsel(reset,BCM2835_GPIO_FSEL_OUTP);         // Reset pin is output
    bcm2835_gpio_write(reset,HIGH);                          // Reset active low
    bcm2835_gpio_fsel(irq,BCM2835_GPIO_FSEL_INPT);           // IRQ pin is input (from DIO0)
    bcm2835_gpio_set_pud(irq,BCM2835_GPIO_PUD_DOWN);         // Pulled DOWN
    bcm2835_gpio_fsel(button,BCM2835_GPIO_FSEL_INPT);        // Button is input
    bcm2835_gpio_set_pud(button,BCM2835_GPIO_PUD_DOWN);      // Pulled DOWN
    SXSetup();
    printf("Ready to send data. Press button to quit... \n");
    send();
    bcm2835_spi_end();
    bcm2835_close();
    printf("================= Clean-up DONE ================ \n");
    return 0;
