OPL-Receiver.bas
#1
#PICAXE 20X2       'One-Page-LoRa-Receiver.bas
#TERMINAL 9600
#no_data
#no_table
'AI LoRa module Ra-01_V1.0  Semtech SX1278. NOT BREADBOARD FRIENDLY !!!!!
'Power supply: 3.3V from computer USB via FTDI module
'LoRa       Colour       Picaxe
'RESET     Brown        B.6
'3.3V       Red             +V         THREE point THREE VOLTS !!!.!!!
'GND       Black           0V        GND
'SCK        Yellow         B.7        hspi sck
'MISO     Orange       B .5       hspi sdi
'MOSI     Green         C.1        hspi sdo
'NSS        White         B.3
'DIO0      Grey           B.0        hint1 IRQ normally LOW pulled DOWN 10k
'ANT                           The antenna, if provided, or ~17cm wire
symbol NSS=B.3
symbol SXReset=B.6
symbol RXBase=0
output NSS
output SXReset
input B.0                                                            ' INT from DIO0
    hspisetup spimode00,spifast
    gosub SXSetup
    hintsetup %00100010                                 'Rising edge on hint1 (B.0)
    pause 5000                                                   'Time to open terminal
    setintflags %00000010,%00000010
    sertxd("Waiting for data...",CR,LF)
loop1:
    pause 100
goto loop1
SXSetup:
    low SXReset
    pauseus 100                                                  'Reset pin low for 100us sets registers to reset values
    high SXReset
    pause 10                                                         'Allow a little time for SX1278 to reset, minimum 5mS
    low NSS
    hspiout($81,$00)                                          'Can only set LoRa mode from sleep mode
    high NSS
    low NSS
    hspiout($81,$88)                                         'LoRa, low frequency mode
    high NSS
    low NSS
    HSPIOUT($91,$BF)                                      'Set up flags for RXdone IRQ
    high NSS
    low NSS
    HSPIOUT($81,$8D)                                     'RXCONTINUOUS, low frequency, LoRa mode (start listening)
    high NSS
interrupt:
    hint1flag=0
    hintflag=0                                                      'Clear Picaxe interrupt flags
    low NSS
    HSPIOUT($92,$40)                                      'Clear LoRa IRQ flags
    high NSS
    low NSS
    HSPIOUT($10)
    HSPIIN(b1)                                                    'Read last packet address
    high NSS
    low NSS
    HSPIOUT($8D,b1)                                        'Set FifoAddrPtr to last packet address
    high NSS
    low NSS
    HSPIOUT($00)
    HSPIIN(b0)                                                    'Read character from FIFO
    high NSS
    sertxd("Received ",#b0,CR,LF)
    setintflags %00000010,%00000010              'Re-arm Picaxe interrupts
N'importe quel module à base de SX1276/78 devrait marcher.
