Have the following code which does not behave as expected.
PICAXE 14m Firmware 9.B
The idea here is that the resolution of readadc10 is desired but as the range of values is small enough to fit in a byte value, the range is shifted (the -205/208 and 271). However the range of values can extend past the 256 that a byte can hold so the idea of the min 0 and Max 255 is to stop overflows.
In practice what is happening is that as the Z axis value reduces to the zero end it jumps to 255 suggesting it is in fact overflowing at the -271 calculation prior to the application of the Min and Max limiters. This is not what I expected from the explanation in the documentation.
(I know the issue can be resolved as the Z axis reads 1G normally instead of 0 so the 'centre' of it's normal range is actually higher than the X and Y axes but this does not explain the behaviour of Min Max)
Any assistance would be appreciated.
Test:
'Test Mode
'Monitor ADC values during setup - Anderson K107 LCD Chip
If pin4 = 1 then sertxd(" X",#b6," Y",#b7," Z",#b8,"?n") ' Pin4 is high only on testing
ReadADC10 1, w0 'Dimension Engineering DE-ACCM3D Accelerometer +- 3G in X,Y & Z Axes
ReadADC10 2, w1 '0g = 1.33V with 0.333v per g, reads 1g in Z axis when static
ReadADC10 3, w2 'May need calibration to local Magnetic Field / position
b6=w0-205 Min 0 Max 255 'centre output on 127, limit within byte range
b7=w1-208 Min 0 Max 255 '1G = 68 units of ADC10 @ 5.0v Ref
b8=w2-271 Min 0 Max 255 'Correct Z Axis to centre point at 1G
pause 500
Goto Test 'Loop for continuous display
EndIf
