On-Chip Counters using 28X2
This code shows how to use the on-chip timers on a PICAXE-28X2 to count external pulses.
Note that both Timer 1 and Timer 3 are activated by an incoming pulse on input pin C.0, Timer 5 is activated by an incoming pulse on input pin C.2
; * HARDWARE                                                      *
#Picaxe 28X2
#No_Table
#No_Data
#Terminal 9600
; * CIRCUIT                                                       *
;              Timer 1               Timer 3               Timer 5
;  -.-   _               -.-   _               -.-
;   |  _|_|_  |           |  _|_|_  |           |         |
;   `---O O-->| 11 C.0    `---O O-->| 11 C.0    |    _    | 11 C.0
;             | 12 C.1              | 12 C.1    |  _|_|_  | 12 C.1
;             | 13 C.2              | 13 C.2    `---O O-->| 13 C.2
;             | 14 C.3              | 14 C.3              | 14 C.3
; * SFR USAGE                                                     *
; | SFR Adresses                                                  |
Symbol  TMR1H           = $CF
Symbol  TMR1L           = $CE
Symbol  T1CON           = $CD
Symbol  T1GCON          = $CC
Symbol  T3GCON          = $B4
Symbol  TMR3H           = $B3
Symbol  TMR3L           = $B2
Symbol  T3CON           = $B1
Symbol  TMR5H           = $50
Symbol  TMR5L           = $4F
Symbol  T5CON           = $4E
Symbol  T5GCON          = $4D
; | Select timer being used                                       |
#Define TIMER 1
#If TIMER = 1
  Symbol  TMRxH         = TMR1H
  Symbol  TMRxL         = TMR1L
  Symbol  TxCON         = T1CON
  Symbol  TxGCON        = T1GCON
#EndIf
#If TIMER = 3
  Symbol  TMRxH         = TMR3H
  Symbol  TMRxL         = TMR3L
  Symbol  TxCON         = T3CON
  Symbol  TxGCON        = T3GCON
#EndIf
#If TIMER = 5
  Symbol  TMRxH         = TMR5H
  Symbol  TMRxL         = TMR5L
  Symbol  TxCON         = T5CON
  Symbol  TxGCON        = T5GCON
#EndIf
; | TxCON Bits                                                    |
Symbol  TMRxCS1_BIT     = bit7
Symbol  TMRxCS0_BIT     = bit6
Symbol  TxCKPS1_BIT     = bit5
Symbol  TxCKPS0_BIT     = bit4
Symbol  TxOSCEN_BIT     = bit3
Symbol  TxSYNC_BIT      = bit2
Symbol  TxRD16_BIT      = bit1
Symbol  TMRxON_BIT      = bit0
; | TxGCON Bits                                                   |
Symbol  TMRxGE_BIT     = bit7
Symbol  TxGPOL_BIT     = bit6
Symbol  TxGTM_BIT      = bit5
Symbol  TxGSPM_BIT     = bit4
Symbol  TxGGO_BIT      = bit3
Symbol  TxGVAL_BIT     = bit2
Symbol  TxGSS1_BIT     = bit1
Symbol  TxGSS0_BIT     = bit0
; * VARIABLES USED                                                *
Symbol  reserveW0      = w0 ; b1:b0
Symbol  counter        = w1 ; b3:b2
Symbol  counter.lsb    = b2
Symbol  counter.msb    = b3
; * POWER ON RESET INITIALISATION                                 *
PoweOnReset:
  ; Stop the counter
  PokeSfr TxCON, 0
  ; Clear the counter
  PokeSfr TMRxL, 0
  PokeSfr TMRxH, 0
  ; Comfigure gating
  TMRxGE_BIT  = 0 ; Gating not enabled / always count
  TxGPOL_BIT  = 1 ; Polarity is active high
  TxGTM_BIT   = 0 ; Toggle Mode disabled
  TxGSPM_BIT  = 0 ; Single-Pulse Mode is disabled
  TxGGO_BIT   = 1 ; Activate gating
  TxGVAL_BIT  = 0 ; Gate value, read-only
  TxGSS1_BIT  = 0 ; Use gate pin
  TxGSS0_BIT  = 0 ; Use gate pin
  PokeSfr TxGCON, b0
  ; Start the counter running
  TMRxCS1_BIT = 1 ; External clock
  TMRxCS0_BIT = 0 ; External clock
  TxCKPS1_BIT = 0 ; Divide by 1 Pre-Scaler
  TxCKPS0_BIT = 0 ; Divide by 1 Pre-Scaler
  TxOSCEN_BIT = 0 ; External LP Oscillator Not Enabled
  TxSYNC_BIT  = 0 ; Don't Synchronise Clock
  TxRD16_BIT  = 0 ; Read as two consecutive 8-bit bytes
  TMRxON_BIT  = 1 ; Counter Enabled
  PokeSfr TxCON, b0
; * MAIN PROGRAM LOOP                                             *
MainLoop:
  Do
    PeekSfr TMRxL, counter.lsb ; Must read LSB then MSB
    PeekSfr TMRxH, counter.msb
    SerTxd( #counter, " " )
    Pause 500
  Loop
