fastgrandad
This should be ridiculously simple but I'm clearly not getting something!
I want to load some default data when initially loading the program but be able to change settings during normal operation that are then retained when switching off and back on again. Otherwise I could have just said let b0 = %00100000 early in the program.
Having failed to get it to work in the full program I wrote a very brief test routine and that doesn't work either.
b0 holds a number of preset states, represented by 0 or 1 in each bit, 0 to 7
#picaxe 20M2
eeprom 6, (%00100000)
debug
read 6 (b0)
pause 5000
end
I was expecting debug to show bits 0 to 7 replicating the eeprom preload
Any ideas?
Thanks
Paul
#picaxe 20M2
debug
read 6 (b0)
pause 5000
end
Any ideas?
Thanks
Paul
