Rampz
Well-known member
I have several sets of code open on my laptop, i'm trying to get the 20X2 working with the altered code from an 08M2, i notice while doing this that my fault counters are reading 65535 the highest they could read, i have several issues anyway i had a circuit set up on the AXE091, the editor is set to 20X2, getting rather hot under the collar, so decide best to go back and get the 08M2 working.
So change editor to 08M2 on the left, build a board up on the second AXE091, put a 08M2 in and power up, load the 08M2 code into the PICaxe, i notice when i check my fault counters that are set to read the last value that was saved, one counter is normal and in line with the number of faults i had created, but the other was still at 65535, as if the editor had written these values to the picaxe, the chip was a new chip, so thought faulty chip maybe so tried another one and it did the same, i altered my code to not retreive previous settings, and then reversed it after a download to try and clear the counters which worked, and after several more downloads everything is working as expected.
My circuit has a recall button to recall the counters after which it deletes the count, but that didn't work on the 65535 one, i have never had this before seems really strange as if the editor wrote eeprom data from the 20X2 to the 08M2 which are both using the same counters in different code set ups
Any one had similar issues, with multiple sets of code open at the same time and working with different sets of code etc?
