noob question
josh_typex
hey guys, the only way i can get a program to run is put the goto main command at the end, thus repeating the program. How do i make a program that will just run through once?
Tom2000
Main:
    ' code in here will run just once
end
Main:
    ' code in here will run forever
end
MoonGoon
You can use the:
"Stop" or "End" commands.
They will both halt your programe till the power is cycled (eg. reset) or your download a new program.
The "End" command makes the PICAXE enter power conservation mode.
The "stop" command does not.
Hope this helps.
josh_typex
thats what i've been doing, but it doesn't run when i turn the switch on...
here is my code:
high 1
pause 1600
low 1
pause 1100
high 1
pause 1100
high 2
pause 300
low 1
low 2
pause 500
high 1
pause 100
low 1
end
