M Manuel Pinto Member Sep 24, 2016 #1 Hi. I built my pcb with micro picaxe 40x2. Like in the picture. My problem is that I can not communicate with the picaxe 40x2! It gives an error like screen shot, someone can help? Thanks in advance Manuel Pinto
Technical Technical Support Staff member Sep 24, 2016 #3 The schematic does not show the required ground connection on pin 3 of the programming header J3.
M Manuel Pinto Member Sep 24, 2016 #4 Thanks for your help. Do you mean, connect the pin 3 wire on GND, like on this new schem?
Technical Technical Support Staff member Sep 24, 2016 #5 Exactly, should be possible via a wire link on the bottom of the pcb.
M Manuel Pinto Member Sep 24, 2016 #6 I ready test, and works perfect. It is error on pcb! Next Version i will be change it. Thanks for your Support.
