david leswell
Hi all. This im first use of a picaxe 14m2 and Logicator V3 5.1
my project is a wind speed metre using a roller ball mouse. (prior to building a 24v 1KW 3 phase wind turbine).
It works fine with a 14m and 6x LEDs, but i needed 8x LED outputs so i have redesigned the PCB for the 14m2.
I can select the 14m2 in the menu, but the pin configuration box is greyed out and unable to secect output pin types.
will i have to use basic code "high portc" and "low portc" as its only to turn on/off an LED.
any help would be great.
many thanks
Dave
many thanks
Dave
