i do not have acess to an older version of programming editor at this moment, and my code is about 1000 lines long.
<code><pre><font size=2 face='Courier'>
;Lcd definitions
SYMBOL RS = 2 ; 0 = Command 1 = Data
SYMBOL EN = 3 ; 0 = Idle 1 = Active
SYMBOL DB4 = 4 ; LCD Data Line 4
SYMBOL DB5 = 5 ; LCD Data Line 5
SYMBOL DB6 = 6 ; LCD Data Line 6
SYMBOL DB7 = 7 ; LCD Data Line 7
SYMBOL RSCMDmask = %00000000 ; Select Command register
SYMBOL RSDATmask = %00000100 ; Select Data register
; Map and movement constants
SYMBOL NMap = 0
SYMBOL NMap2 = 255
SYMBOL WE = 1
SYMBOL NS = 16
SYMBOL Still = 151
SYMBOL N = %00001000
SYMBOL E = %00000100
SYMBOL S = %00000010
SYMBOL W = %00000001
Symbol calibrate = b2
Symbol LDR1 = b3
SYMBOL NOGOMap = w1
Symbol LDR2 = b4
symbol LDR3 = b5
SYMBOL CellAdd = w2
symbol Queue = w2
symbol LDR4 = b6
Symbol LDR5 = b7
symbol Path = w4
Symbol LDR6 = b8
Symbol LDR7 = b9
SYMBOL LeftServe = b10
SYMBOL RightServe = b11
SYMBOL Facing = b12
SYMBOL Cell = b13
SYMBOL TrackDest = b14
SYMBOL TrackPos = b15
SYMBOL Map1 = b16
SYMBOL Map2 = b17
SYMBOL TopSpeed = b19
Symbol Flood = b20
SYMBOL BackUpPtr = b21
SYMBOL NextCell = b22
SYMBOL pos = b24
SYMBOL getting = b25
SYMBOL bit = b26
SYMBOL rsbit = b27
SYMBOL North = 1
SYMBOL East = 2
SYMBOL South = 3
SYMBOL West = 4
'LCD subs use the first 5 bytes
EEPROM 6,("set sensitivity"
EEPROM 21, ("Ready"
EEPROM 26, ("Facing undefined"
EEPROM 43,("Cell:"
EEPROM 48,("Going:"
EEPROM 54,("Creating Maps"
EEPROM 68,("Sucess!"
EEPROM 75,("Running to"
EEPROM 85,("Start "
EEPROM 91,("Center"
EEPROM 97,("Running at 16mhz"
'*** PART 1 ***
Setfreq em16
GOSUB InitialiseLcd
ptr = 0
b2 = 50
PowerOnReset: 'get and display the values of the sensors, whilst getting an average: can be removed if code is to big.
gosub sense
pos = $80
getting = LDR1
gosub Dis
pos = $84
getting = LDR2
gosub Dis
pos = $88
getting = LDR3
gosub Dis
pos = $C0
getting = LDR4
gosub Dis
pos = $C4
getting = LDR5
gosub Dis
pos = $C8
getting = LDR6
gosub Dis
pos = $CC
getting = LDR7
gosub Dis
@ptr =LDR1
inc ptr
@ptr =LDR2
inc ptr
@ptr =LDR3
inc ptr
@ptr =LDR4
inc ptr
@ptr =LDR5
inc ptr
@ptr =LDR6
inc ptr
@ptr =LDR7
inc ptr
if ptr != 28 then PowerOnReset
gosub InitialiseLcd
FOR getting = 6 TO 20
READ getting,bit
GOSUB SendDataByte
NEXT
gosub Sensitivity
ptr = 0
gosub Average
ptr = 1
gosub Average
ptr = 2
gosub Average
ptr = 3
gosub Average
ptr = 4
gosub Average
ptr = 5
gosub average
ptr = 6
gosub average
ptr = 28
goto init
Average:
w0 = 0
for getting = 1 to 4
w0 = w0 + @ptr
ptr = ptr +7
Next
@ptr = w0 / 4
@ptr = @ptr + calibrate
Dis:
bit = pos
Gosub SendCmdByte
BINTOASCII getting,b23,b22,b21
bit = b23
gosub SendDataByte
bit = b22
gosub SendDataByte
bit = b21
gosub SendDataByte
Return
Sensitivity:
pos = $C0
getting = calibrate
gosub Dis
if pin1 = 1 then inc calibrate
if calibrate = 45 then let calibrate = 55
getting = calibrate
gosub Dis
if pin2 = 1 then return
release:
if pin1 = 0 then Sensitivity
goto release
'*** PART2 ***
init:
Facing = North
Cell = 0
TopSpeed = 15
ptr = 0
hi2csetup i2cmaster, %10100010, i2cslow, i2cword
GOSUB InitialiseLcd
FOR getting = 54 TO 66
READ getting,bit
GOSUB SendDataByte
NEXT
for w0 = 0 to 255 Step 8 'set the first 256 bytes to be the map data... all zeroed
hi2cout w0,(NMap,NMap,NMap,NMap,NMap,NMap,NMap,NMap)
pause 20
Next w0
bit = $2E
gosub SendDataByte
for w0 = 256 to 511 step 8 'set the second 256 bytes to be the NO GO regester! all 255, set to zero when mouse enters the cell
hi2cout w0,(NMap2,NMap2,NMap2,NMap2,NMap2,NMap2,NMap2,NMap2)
pause 20
Next w0
bit = $2E
gosub SendDataByte
for w0 = 512 to 767 step 8 'set the last 256 to be the flood fill map.
pause 20
Next w0
bit = $2E
gosub SendDataByte
gosub InitialiseLcd
FOR getting = 68 TO 74
READ getting,bit
GOSUB SendDataByte
NEXT
bit = 0
let bit = bit + %00000010 'make sure that the wall behind the mouse is set
gosub sense2
if bit7 = 1 then let bit = bit + %00001000
if bit2 = 1 then let bit = bit + %00000001
if bit5 = 1 then let bit = bit + %00000100
GOSUB InitialiseLcd
FOR getting = 21 TO 25
READ getting,bit
GOSUB SendDataByte
NEXT
bit = $C0
gosub SendCmdByte
FOR getting = 97 TO 113
READ getting,bit
GOSUB SendDataByte
NEXT
' wait for the user to flick the switch before starting
Ready:
if pin2 = 1 then Ready
GOSUB InitialiseLcd
FOR getting = 43 TO 47
READ getting,bit
GOSUB SendDataByte
NEXT
'b20 = 0
SearchLoop:
'inc b20
'if b20 = 10 or b20 = 1 then
'for NOGOMap = 0 to 768 step 8
' ptr = 0
' hi2cin NOGOMap,(@ptrinc,@ptrinc,@ptrinc,@ptrinc,@ptrinc,@ptrinc,@ptrinc,@ptr)
' ptr = 0
' sertxd (#@ptrinc,9,#@ptrinc,9,#@ptrinc,9,#@ptrinc,9,#@ptrinc,9,#@ptrinc,9,#@ptrinc,9,#@ptrinc,13)
' pause 10
'Next NOGOMap
'endif
'this is the main searching loop that will be called when ever the mouse enters a new cell.
bit = 0
Gosub sense2
if Facing = North then ' do checks to see what walls are open and fill out the map sheet accordingly.
' Bit format = %____NESW 1 for a wall present
if bit7 = 1 then:bit = bit + N:endif ' this block takes the sensor readings and put the data into the correct format
if bit2 = 1 then:bit = bit + W:endif ' for the maze map, no matter what way it is facing. it does not need to deal with
if bit5 = 1 then:bit = bit + E:endif ' the data for the previous cell because that will have already been added when it
Gosub MapW ' was there.
elseif Facing = East then
if bit7 = 1 then:bit = bit + E:endif
if bit2 = 1 then:bit = bit + N:endif
if bit5 = 1 then:bit = bit + S:endif
Gosub MapW
elseif Facing = South then
if bit7 = 1 then:bit = bit + S:endif
if bit2 = 1 then:bit = bit + E:endif
if bit5 = 1 then:bit = bit + W:endif
Gosub MapW
elseif Facing = West then
if bit7 = 1 then:bit = bit + W:endif
if bit2 = 1 then:bit = bit + S:endif
if bit5 = 1 then:bit = bit + N:endif
Gosub MapW
'display an error screen
bit = $01
gosub SendCmdByte
'string eepromed at the top of the file, because it cannot be done within an IF block.
FOR getting = 26 TO 42
READ getting,bit
GOSUB SendDataByte
NEXT
let NOGOMap = Cell + NMap2 ' point to the same position in the nogo map.
gosub NGWL
Direction: ; depending on the direction the mouse is facing select the best cell to move into.
; Must also increment the cell. NEED TO ADD PRIORITY TO UNSEEN CELLS
bit8 = 0
If Facing = North then 'NORTH FACING
NOGOMap = NOGOMap + NS
gosub NGR
if bit7 = 0 and @ptr = NMap2 then
gosub Foward
Cell = Cell + NS
bit8 = 1
gosub NGWL
if bit8 = 1 then FinishDirection
NOGOMap = NOGOMap - NS
NOGOMap = NOGOMap - WE
gosub NGR
if bit2 = 0 and @ptr = NMap2 then
gosub Left
Facing = West
gosub Foward
Cell = Cell - WE
bit8 = 1
gosub NGWL
NOGOMap = NOGOMap + WE + WE
gosub NGR
if bit5 = 0 and @ptr = NMap2 then
gosub Right
Facing = East
gosub Foward
Cell = Cell + WE
bit8 = 1
gosub NGWL
if bit7 = 0 then
gosub Foward
Cell = Cell + NS
elseif bit2 = 0 then
gosub Left
Facing = West
gosub Foward
Cell = Cell - WE
elseif bit5 = 0 then
gosub Right
Facing = East
gosub Foward
Cell = Cell + WE
elseif Bit7 = 1 and bit2 = 1 and bit5 = 1 then
gosub Right
gosub Right
Facing = South
gosub Foward
Cell = Cell - NS
'END OF NORTH FACING
elseif Facing = East then ' EAST FACING
gosub NGR
gosub Foward
Cell = Cell + WE
bit8 = 1
gosub NGWL
gosub NGR
gosub Left
Facing = North
gosub Foward
Cell = Cell + NS
bit8 = 1
gosub NGWL
gosub NGR
gosub Right
Facing = South
gosub foward
Cell = Cell - NS
bit8 = 1
gosub NGWL
if bit7 = 0 then
gosub Foward
Cell = Cell + WE
gosub Left
Facing = North
gosub Foward
Cell = Cell + NS
gosub Right
Facing = South
gosub foward
Cell = Cell - N
gosub Right
gosub Right
Facing = West
gosub Foward
Cell = Cell - WE
NOGOMap = NOGOMAp - NS
gosub NGR
gosub Foward
Cell = Cell - NS
bit8 = 1
gosub NGWL
gosub NGR
Gosub Left
Facing = East
gosub Foward
Cell = Cell + WE
bit8 = 1
gosub NGWL
gosub NGR
gosub Right
Facing = West
gosub Foward
Cell = Cell - WE
bit8 = 1
gosub NGWL
if bit7 = 0 then
gosub Foward
Cell = Cell - NS
Gosub Left
Facing = East
gosub Foward
Cell = Cell + WE
gosub Right
Facing = West
gosub Foward
Cell = Cell - WE
gosub Right
gosub Right
Facing = North
gosub Foward
Cell = Cell + NS
gosub NGR
gosub Foward
Cell = Cell - WE
bit8 = 1
gosub NGWL
gosub NGR
if bit2 = 0 and @ptr = 0 then
gosub Left
Facing = South
gosub Foward
Cell = Cell - NS
bit8 = 1
gosub NGWL
NOGOMap = NOGOMap + NS + NS
gosub NGR
if bit5 = 0 and @ptr = 0 then
gosub Right
Facing = North
gosub Foward
Cell = Cell + NS
bit8 = 1
gosub NGWL
if bit7 = 0 then
gosub Foward
Cell = Cell - WE
gosub Left
Facing = South
gosub Foward
Cell = Cell - NS
gosub Right
Facing = North
gosub Foward
Cell = Cell + NS
gosub Right
gosub Right
Facing = East
gosub Foward
Cell = Cell + WE
FinishDirection:
if Cell = 119 or Cell = 120 or Cell = 135 or Cell = 136 then FFill
getting = Cell
pos = $89
gosub Dis
'pause 1000 For debug purposes
goto SearchLoop
FFill:
'create and initialise a queue with 256 elements sequencial after the 768
'create a routing map as an array of 256 bytes ...Tick
'fill the array with the value 255 ...Tick
'fill the target cells(s) with the value 0 ...Tick
'add the target cell locations to the queue
'while there are items in the queue
' get a location from the tail of the queue
'if the cell does not contains the value 255 then
' for each accessible, unfilled neighbour
' put in it a value one more than the current cell
' add it to the queue
' end for
'end if
'end while
for ptr = 127 to 36
@ptr = 255
next ptr
hi2cout 631,(0,0)'set the middle of the flood fill map ready for after the mapping sesh
pause 5
hi2cout 647,(0,0)
pause 5
@ptr = Cell
Flood = 0
BackUpPtr = 36
FFP2:
do while @ptr != 0
w2 = @ptr
hi2cin w2,(bit)
w3 = @ptr + 512
hi2cin w3 ,(Flood) 'import the Cells Flood Value in order to have a reference for the next cells that will be checked
Flood = Flood + 1
ptr = Map2
let Map1 = bit & %00000001 'check the Cell west of the current one
if Map1 = 0 then
w2 = w2 - WE
hi2cin w2,(Map2)
if Map2 = NMap2 then
inc ptr
@ptr = w2
hi2cout w2,(Flood)
pause 20
w2 = w2 + WE
let Map1 = bit & %00000010 'check the Cell South of the current one
if Map1 = 0 then
w2 = w2 - NS
hi2cin w2,(Map2)
inc ptr
@ptr = w2
hi2cout w2,(Flood)
pause 20
w2 = w2 + NS
let Map1 = bit & %00000100 'check the Cell East of the current one
if Map1 = 0 then
w2 = w2 + WE
hi2cin w2,(Map2)
inc ptr
@ptr = w2
hi2cout w2,(Flood)
pause 20
w2 = w2 - WE
let Map1 = bit & %00001000 'check the Cell North of the current one
if Map1 = 0 then
w2 = w2 + NS
hi2cin w2,(Map2)
inc ptr
@ptr = w2
hi2cout w2,(Flood)
pause 20
w2 = w2 - NS
Map2 = ptr
inc BackUpPtr
ptr = BackUpPtr
' Create a route which the mouse can follow foward and reverse
ptr = 36
w3 = 512
w2 = 0
Path = 768
bit0 = 0
inc @ptr
hi2cin w2,(bit)
hi2cin w3,(Map2)
if Map1 = 0 then
w2 = w2 - WE
hi2cin w2,(Map1)
if Map1 < Map2 then
b8 = w2
hi2cout Path,(b8)
pause 20
bit0 = 1
if bit0 = 1 then FFP3
w2 = w2 + WE
if Map1 = 0 then
w2 = w2 - NS
hi2cin w2,(Map1)
if Map1 < Map2 then
b8 = w2
hi2cout Path,(b8)
pause 20
bit0 = 1
w2 = w2 + NS
if Map1 = 0 then
w2 = w2 + WE
hi2cin w2,(Map1)
if Map1 < Map2 then
b8 = w2
hi2cout Path,(b8)
pause 20
bit0 = 1
w2 = w2 - WE
if Map1 = 0 then
w2 = w2 + NS
hi2cin w2,(Map1)
if Map1 < Map2 then
b8 = w2
hi2cout Path,(b8)
pause 20
w2 = w2 - NS
FFP3:
if b8 = 119 or Cell = b8 or Cell = b8 or Cell = b8 then exit
inc Path
BackUpPtr = @ptr
b16 = path
gosub InitialiseLcd
FOR getting = 75 TO 84
READ getting,bit
GOSUB SendDataByte
NEXT
RunTS:
gosub InitialiseLcd
FOR getting = 85 TO 90
READ getting,bit
GOSUB SendDataByte
NEXT
Cell = 0
for b23 = b16 to 0
dec Path
hi2cin Path,(NextCell)
gosub PathFinder
next b23
pause 1000 ' for debugging purposes
RunTC:
gosub InitialiseLcd
FOR getting = 91 TO 96
READ getting,bit
GOSUB SendDataByte
NEXT
for b23 = 0 to b16
inc Path
gosub PathFinder
next b23
goto RunTS
PathFinder:
b8 = NextCell - Cell
if b8 = 1 then
gosub Right
Facing = East
gosub Foward
elseif b8 = 16 then
gosub Foward
elseif b8 = 255 then
gosub Left
Facing = West
gosub Foward
elseif b8 = 240 then
gosub Right
gosub Right
Facing = South
gosub Foward
if b8 = 1 then
gosub Foward
elseif b8 = 16 then
gosub Left
Facing = North
gosub Foward
gosub Right
gosub Right
Facing = West
gosub Foward
gosub Right
Facing = South
gosub Foward
if b8 = 1 then
gosub Left
Facing = East
gosub Foward
elseif b8 = 16 then
gosub Right
gosub Right
Facing = North
gosub Foward
gosub Right
Facing = West
gosub Foward
gosub Foward
if b8 = 1 then
gosub Right
gosub Right
Facing = East
gosub Foward
elseif b8 = 16 then
gosub Right
Facing = North
gosub Foward
gosub Foward
gosub Left
Facing = South
gosub Foward
READ getting,bit
GOSUB SendDataByte
NEXT
Cell = NextCell
'*** Tracking ***
Foward: ' go foward one cell (18cm)
TrackDest = 41
ptr = 0
for TrackPos = 0 to TrackDest
gosub sense2
let bit = b0 & $80
if bit = $80 then
if TrackPos => 13 then Exit
if TrackPos < 13 then 'if the mouse didnt make up the full distance, then compensated now, so continue
if Facing = North then: Cell = Cell - NS
elseif Facing = South then: Cell = Cell + NS
elseif Facing = East then: Cell = Cell - WE
elseif Facing = West then: Cell = Cell + WE
Exit
;movement correction.
let bit = b0 & $7E
if bit = %01101100 or bit = %01100000 or bit = %00001100 or bit = %01001000 or bit = %01101000 or bit = %01001100 or bit = %01000000 or bit = %00001000 then'Tis vearing to the right hand side!!!!!!!! sort it out!
RightServe = Still - 5
LeftServe = Still + TopSpeed
elseif bit = %00110110 or bit = %00110000 or bit = %00000110 or bit = %00010010 or bit = %00110010 or bit = %00010110 or bit = %00000010 or bit = %00010000 then
LeftServe = Still + 5
RightServe = Still - TopSpeed
'elseif TrackPos > 13 then
'if bit = %00100110 or bit = %01100100 or bit = %01110110 or bit = %01101110 then Exit
'LDR4 = @ptrdec & %00100100
'LDR3 = @ptrinc & %00100100
'if LDR4 != LDR3 then Exit ' leave the loop if the mouse goes accross a wall boundry.
Gosub Speed
After:
pause 80
Next TrackPos
LeftServe = Still
RightServe = Still
gosub Speed
Left: ' turn 90deg CCW
TrackDest = 21
LeftServe = Still - TopSpeed
gosub Speed
gosub sense2
if TrackPos > 18 then
let bit = b0 & %00100100
if bit != 0 then
pause 80
Exit
pause 80
next Trackpos
LeftServe = Still
RightServe = Still
gosub Speed
Right: ' turn 90deg CW
TrackDest = 21
RightServe = Still + TopSpeed
gosub Speed
gosub sense2
if bit != 0 then
pause 80
Exit
pause 80
next Trackpos
LeftServe = Still
RightServe = Still
gosub Speed
Speed:
servo 0,LeftServe
servo 1,RightServe
'*** MAP CONTROL ***
MapW: ;Bit format = %____NESW 1 for a wall present
ptr = 0
CellAdd = Cell
gosub MapR
sertxd (#bit,9)
bit = bit | @ptr
hi2cout CellAdd, (bit) ' output the current wall configuration
sertxd (#Cell,9,#bit,9,#@ptr,10)
pos = $C2
getting = bit
gosub Dis
NorthCell: ' Update the surrounding cells so that some data has already been collected when the mouse enters a
Map2 = bit & %00001000 ' cell. This will not set the other cells as ok to enter though. (NOGO = 0)
if Map2 = %00001000 then
CellAdd = Cell + N/S
gosub MapR
Map1 = @ptr | Map2
hi2cout CellAdd,(Map1)
pause 20
EastCell:
Map2 = bit & %00000100
if Map2 = %00000100 then
CellAdd = Cell + W/E
gosub MapR
Map1 = @ptr | Map2
pause 20
SouthCell:
Map2 = bit & %00000010
if Map2 = %00000010 then
CellAdd = Cell - N/S
gosub MapR
Map1 = @ptr | Map2
pause 20
WestCell:
Map2 = bit & %00000001
if Map2 = %00000001 then
CellAdd = Cell - W/E
gosub MapR
Map1 = @ptr | bit
pause 20
Return
MapR:
hi2cin CellAdd, (@ptr)
NGR: ' read the status from the no go register
hi2cin NOGOMap,(@ptr)
NGWL:
hi2cout NOGOMap,(0) ' write the no go stautus low for the current cell (ok to enter)
pause 20
NGWH:
hi2cout NOGOMap,(NMap2) 'write the no go status high (not ok to go into)
'*** SENSOR CONTROL ***
sense2:
gosub sense
ptr = 28
if LDR1 > @ptrinc then: bit1 = 1
else bit1 = 0
if LDR2 > @ptrinc then: bit2 = 1
else bit2 = 0
if LDR3 > @ptrinc then: bit3 = 1
else bit3 = 0
if LDR4 > @ptrinc then: bit4 = 1
else bit4 = 0
if LDR5 > @ptrinc then: bit5= 1
else bit5 = 0
if LDR6 > @ptrinc then: bit6 = 1
else bit6 = 0
if LDR7 > @ptrinc then: bit7 = 1
else bit7 = 0
sense:
readadc 0,LDR1
readadc 1,LDR2
readadc 2,LDR3
readadc 3,LDR4
readadc 5,LDR5
readadc 6,LDR6
readadc 7,LDR7
'******LCD SUBS*********'
InitialiseLcd:
FOR getting = 0 TO 5
READ getting,bit
GOSUB SendInitCmdByte
NEXT
' Nibble commands - To initialise 4-bit mode
EEPROM 0,( $33 ) ; %0011---- %0011---- 8-bit / 8-bit
EEPROM 1,( $32 ) ; %0011---- %0010---- 8-bit / 4-bit
' Byte commands - To configure the LCD
EEPROM 2,( $28 ) ; %00101000 %001LNF00 Display Format
EEPROM 3,( $0C ) ; %00001100 %00001DCB Display On
EEPROM 4,( $06 ) ; %00000110 %000001IS Cursor Move
; L : 0 = 4-bit Mode 1 = 8-bit Mode
; N : 0 = 1 Line 1 = 2 Lines
; F : 0 = 5x7 Pixels 1 = N/A
; D : 0 = Display Off 1 = Display On
; C : 0 = Cursor Off 1 = Cursor On
; B : 0 = Cursor Steady 1 = Cursor Flash
; I : 0 = Dec Cursor 1 = Inc Cursor
; S : 0 = Cursor Move 1 = Display Shift
EEPROM 5,( $01 ) ; Clear Screen
RETURN
SendInitCmdByte:
PAUSE 15 ; Delay 15mS
SendCmdByte:
rsbit = RSCMDmask ; Send to Command register
SendDataByte:
outpins = bit & %11110000 | rsbit ^ $80; Put MSB out first
high EN
pause 1
low EN ; Give a 10uS pulse on E
outpins = bit * %00010000 | rsbit ^ $80; Put LSB out second
high EN
pause 1
rsbit = RSDATmask ; Send to Data register next
RETURN
'******* END OF LCD SUBS********'
</font></pre></code>
I cannot see anything wrong with it, and we have already had several problems with the program editor....
Here now at the competition, have a few hours before the deadline!!!
i pray to hippy...
