The Nesbit problem has finally been solved by a British company <A href='http://loc8tor.com/' Target=_Blank>External Web Link</a>. This locator system uses 2.4Ghz RFID beacons and gives you range and direction on the cellphone sized locator, and also can be set to give an alarm when the RFID tag goes astray (beyound one of 3 preset ranges). Up to 600' range and tracks to within 1". Available in the US now for about USD$99.
Now, if it can be hacked for interface to the Picaxe as a datalogger or other purposes, this might be a really nice gadget with lots of possibilities. Assuming you can have 2 locators per tag (not necessarily correct), you could do triangulation. However, if you have range and direction, that is not really needed, is it?
It would also make a nice addition to the ultimate fire control system for R/C Model Warship Combat, or for an automated convoy system (where you need to determine the position of the convoy ships relative to each other).
Track control system for R/C cars?
Lots of possibilities.
Now Nesbit's owner will be able to sleep better at night, knowing Nesbit hasn't escaped or been nicked. And can find the little dear under the bushes. ;-)
I found the advert for this device in X-tremegeek, and the lights just went on.
Wreno
Wreno
