Neoway M590 GSM Texter
neiltechspec
Found a Neoway M590 GSM SMS Text Module on fleabay for £7.90.
Came setup for 9600baud, uses TTL simple AT commands for comms & runs off 3.3v
It's really easy to use, but suggest the datasheets are studied as well.
#rem
M590 GSM Texter 9600baud
V1.0 Sept 2016
On Power Up module sends :-
MODEM:STARTUP then
+PBREADY when ready for AT commands
Send AT+CMGF=1 for plain text mode
Send AT+CSCS="GSM" for GSM default alphabet
Delete all stored messages
AT+CMGD=0,4
OK
Send Network Check
AT+CREG?
response if registered
+CREG: 0,1
To send SMS Text
AT+CMGS="07702XXXXXX"<CR>(0x0D) to send,
when the indicating symbol &#8216;>&#8217;
appears, input SMS content
"Test Message"
CTRL+Z(0x1A) to send.
Data to   M590 = C.2
Data from M590 = C.3
Ring from M590 = C.4
Input1 on B.1
Input2 on B.2
Input3 on B.3
Input4 on B.4
LED on B.5
#endrem
#picaxe 14M2
#no_data
#terminal 19200
init:
	setfreq m16
	low B.5
	pause 4000
	sertxd("Waiting for Modem Init",13,10)
	serin C.3,T9600_16,("+PBREADY")
	sertxd("Modem Initialised",13,10)
	pause 4000
	serout C.2,T9600_16,("AT+CMGF=1",13)
	pause 4000
	serout C.2,T9600_16,("AT+CSCS=",34,"GSM",34,13)
	pause 4000
	serout C.2,T9600_16,("AT+CMGD=0,4",13)
	gosub check
	if pinB.1 = 0 then gosub alarm1
	if pinB.2 = 0 then gosub alarm2
	if pinB.3 = 0 then gosub alarm3
	if pinB.4 = 0 then gosub alarm4
	gosub check
alarm1:
	serout C.2,T9600_16,("AT+CMGS=",34,"07702XXXXXX",34,13)
	pause 4000
	serout C.2,T9600_16,(34,"Doorbell",34)
	pause 4000
	serout C.2,T9600_16,(26)
	sertxd("SMS 1 sent",13,10)
	pause 40000
	do until pinB.1=1 loop
alarm2:
	pause 4000
	serout C.2,T9600_16,(34,"House Alarm",34)
	pause 4000
	sertxd("SMS 2 sent",13,10)
	pause 40000
	do until pinB.2=1 loop
alarm3:
	pause 4000
	serout C.2,T9600_16,(34,"Alarm 3",34)
	pause 4000
	sertxd("SMS 3 sent",13,10)
	pause 40000
	do until pinB.3=1 loop
alarm4:
	pause 4000
	serout C.2,T9600_16,(34,"Alarm 4",34)
	pause 4000
	sertxd("SMS 4 sent",13,10)
	pause 40000
	do until pinB.4=1 loop
check:
	pause 4000
	serout C.2,T9600_16,("AT+CREG?",13)
	serin [4000],C.3,T9600_16,("+CREG: "),b1,b2,b3
	if b1 = 48 and b3 = 48 then
	 sertxd("Not Searching",13,10)
	 low B.5
	 goto check
	if b1 = 48 and b3 = 49 then
	sertxd("Network ok",13,10)
	 high B.5
	if b1 = 48 and b3 = 50 then
	 sertxd("Refused",13,10)
	 low B.5
	 goto check
	endiF
	if b1 = 48 and b3 = 51 then
	 sertxd("Searching",13,10)
	 low B.5
	 goto check
	sertxd("Network Invalid response",13,10)
	goto check
Neil
lbenson
Interesting part. Thanks for the code.
I just ordered 2 in kit form for under $2 U.S. each including shipping. Can you post the datasheet?
neiltechspec
Unfortunately, the file sizes are too large for this forum.
Easy enough to find on google though - I did.
They are called:
neoway-m590-hardware-design-manual-v1.pdf
neoway-m590-at-command-sets-v3.pdf
Just be aware, the datasheets say 115k is the default baud rate. Mine came as 9600.
Neil.
zorgloub
Hello neiltechspec, Hello everyone,
For info, I had already tested these Neoway M950 modules but they do not seem very sensitive and the connection to the network is particularly painful.
So I'll test the Sim800 and Sim900 ...
cordially
