Hi;
I'm using the picaxe 8M to attempt control on/off of a microtransmitter which needs (12-13.8V) to operate through a 8 cell AA battery pack. I realize the 8M has less than 5V output on pin 2 which I've programmed to turn the transmitter on/off. Pin 2 high, wait xx, pin 2 low...etc... but obviously cannot initiate the correct 12V power output to the transmitter.
In a general sense, what's the best way to use the 8M to control a larger voltage in that 12-13.8V range? (insert helpful hint here).
My apologies for my limited electrical background. Just need a helpful hint to muddle through. Looked through the forum but can't find anything significant for my problem. A link or two would work too
thanks
Dan
thanks
Dan
