Hello all,
Have a mystery stepper motor that I am attempting to use.
Should be noted that this is my first attempt to date using steppers with Picaxe.
The information I can provide on the motor- (Google wasent friendly to me on this, I couldent find anything on this)
Printed on back- 35s1n15dcnr
100 ohm
4627 MB
5 wires- Yellow, Red, Brown, White, Blue
Placing an LED in the connector, all pairs light up when shaft is spun.
Resistance testing led me to the WHITE being the center tap. 200 ohm vs 100 ohm
I am assuming this is a Unipolar?? As this only has one center tap correct?
Next step is to connect this to my AXE117 board, as this has the ULN2003 to drive this.
I got stumped when I came to manual 3 pg.16
It shows a separate 12v supply on a "RED" wire. How do I know for sure that this is a 12V motor? i would presume this is a 24v
Also, I am not following how to connect this motor to the Axe117 from the diagram on pg 16.
Any pointers for me how to get this motor up and running? What material am i missing?
Thanks!
Information I used to get this far-
http://www.easterngeek.com/2010/06/how-to-identify-stepper-motor-lead.html
http://www.instructables.com/id/Find-Bipolar-Stepper-Motor-Coil-Pairs/?lang=es
Picaxe Manual 3
100 ohm
4627 MB
Thanks!
Picaxe Manual 3
