Rampz
Well-known member
I expected there would be issues, reading through the manuals i can't yet see what they are, I have "TIME = 0" on the 08m2 that is fine but not liked when i do a check having changed the editor to 20X2, i bet there will be many more issues as i resolve each one, is there a guide somewhere to help the transition etc?
So it seems TIME is a m2 only command
The code i want to move over
#picaxe 08m2
SetFreq M16
i know the 08m2 needs changing to 20X2
I see the 20X2 runs at 64mhz so i guess i need to delete "SetFreq M16" and i assume it will throw all my time settings based on M16 also?
#picaxe 08m2
SetFreq M16
' Code snippets from Rampz, Goeytex & Jack Burns
#REM
#no_data
#terminal 19200
'| Constants |
symbol BTN = PinC.3 '// Tilt Switch
symbol btn1 = PinC.1 ' memory recall button
symbol BTN2 = PinC.5 ' tilt switch reset switch, new xxxx
Symbol LED = C.4 ' mosfet output
Symbol LED2 = C.0 ' Originally used C.0 but changed to C.1 as SERTXD messages are now used
symbol released = 0
Symbol Pressed = 1
Symbol LowBattLevel = 104 ' Low voltage threshold x 10 (104 = 10.4v)
Symbol AvgCount = 10 ' Number of ADC readings to be averaged when calculating battery voltage
Symbol MaxRunTime = 6 ' Time in seconds. (Set low for testing, 30 required)
Symbol MinRunTime = 501 '// 501 = 400 ms approx. Adjust this value to change delay time after button released
Symbol LowBattDuration = 10 'set at 10 seconds
Symbol ChargeReadInterval = 4000 ' 4000 = 1 sec @ 16Mhz Take a reading every second
'// TEMPORARILY SET ChargeReadCount TO 20 WHILE BENCH TESTING (This will make testing quicker).
'// ChargeReadCount NEEDS TO BE 3600
Symbol ChargeReadCount = 20 ' Normally 3600 readings while battery charges, 1800 30 mins
'// 3600 Readings at 1 sec = 1 hour (Combination of ChargeReadInterval & ChargeReadCount)
symbol highbattvolt = 140 'battery on again voltage 115 = 11.5v
'| Variables Used |
symbol ReserveB1 = b1 ' Used in "MeasureBatteryVoltage" routine
symbol ReserveB2 = b2 ' Used in "MeasureBatteryVoltage" routine
symbol ReserveB3 = b3 ' Used in "MeasureBatteryVoltage" routine
symbol Counter = W2 ' Used in several places
symbol ADCvalue = W3 ' Used in "MeasureBatteryVoltage" routine
symbol ADCavg = W4 ' Used in "MeasureBatteryVoltage" routine
symbol Volts = W5 ' Used in several places
symbol VmonCount = W6 ' Used in battery monitoring loop
symbol LowBattCount = W7 ' Used for testing batt low for 10 seconds
symbol stallfaultcount = W8 ' counter for how many times stalled
symbol FlashCount = W9 ' Put this line at start of main code.
symbol LVDfaultcount = W10 ' counter for how many times low voltage disconnect happened
symbol C5counter = W11 ' counter to make C5 an input after 30 seconds
init: ' initialisation code
for c5counter = 1 to 120
next c5counter
disconnect
sertxd("coding by Rampz, Goeytex and Jack Burns V3:04/12/21",13,10) 'heading main users involved in code
read 0,WORD stallfaultcount ' To fill counter with previous faults after power fail
read 2,WORD LVDfaultcount ' To fill counter with previous faults after power fail
MAIN:
if btn1= released then 'added to check btn1 during main program, altered to high going low
sertxd("Memory Recall, LVD then Battery Fail",13,10) 'added to display on terminal
sertxd(" (stallfaultcount: ",#stallfaultcount,")",13,10) 'as above
sertxd(" (LVDfaultcount: ",#LVDfaultcount,")",13,10) 'as above
gosub memoryrecall 'added to send to memory recall if btn1 pressed
end if 'added as required
IF BTN = Released then
sertxd("Tilt switch operated",13,10)
High LED
StartCounter:
Time = 0
Counter = MinRunTime ' approx 400 ms
Do : Loop while BTN = Released and Time < MaxRunTime
if Time >= MaxRunTime then gosub MotorStalled
'// If here then switch released
'// Time Out after 400 ms (however, no delay if motor was previously stalled)
'// If another Press detected then reset timer
Do While Counter > 1
Counter = Counter - 1
If BTN = Released then 'start over
Goto StartCounter
END IF
Loop
sertxd("Timed out",13,10)
LOW LED
END IF
' Now measure battery voltage approx once a second
inc VmonCount
if VmonCount>1000 then ' 1000 = approx 1 sec. Measure battery voltage approx once a second
VmonCount = 0
gosub MeasureBatteryVoltage
sertxd("Main Loop - Battery level: ")
gosub ShowVoltage
sertxd(" (LowBattCount: ",#LowBattCount,")",13,10)
if Volts <= LowBattLevel then ' Set at 10.4 Volts in "Constants" section
inc LowBattCount
if LowBattCount > LowBattDuration then ' approx 10 seconds
gosub LowBatteryVoltage
end if
LowBattCount = 0 ' reset count if battery doesn't stay low for specified duration
end if
end if
GOTO MAIN:
MotorStalled:
sertxd("Motor Stalled",13,10)
stallfaultcount = stallfaultcount + 1 ' added
write 0,WORD stallfaultcount ' This stores the "stallfaultcount" in EEPROM location 0
SERTXD("motor stalled count = ",#stallfaultcount ,cr,lf)
low LED '// Turn motor drive off
high LED2 '// Turn fault light on
do : loop while BTN = Released and btn2 = released '// Wait for switch to be released, btn2 = released resets motorstalled condition
'// If here then switch has been released or btn2 pressed
low LED2 '// Turn fault light off
sertxd("Tilt switch has now reset",13,10)
Counter = 0 ' Set to zero so that it falls through 400 ms delay after return to main code
MeasureBatteryVoltage:
'// Measure average voltage over 10 readings.
ADCavg = 0 'Initialise to 0
for b1 = 1 to AvgCount 'adjust above for readings to average
ReadADC10 C.2,ADCvalue
ADCavg = ADCavg + ADCvalue
next b1
ADCavg = ADCavg / AvgCount
' Convert ADC Value to Voltage
Volts = ADCavg **64064 ' Convert 1023 to 1000 steps (**64064) for 5.00v reference
'volts = volts *65 ' correction needed to make 102
'volts = volts /64 ' read 104
Volts = Volts *16 ' Multiply by Vin (Fullscale 16v)(R1 22K)(R2 10K)
Volts = Volts /100 ' Reduce to 3 digits
'// Volts here will be 10 times actual voltage, eg 104 = 10.4v , 115 = 11.5v
ShowVoltage:
BinTOASCII Volts, b3,b2,b1 : IF b3 = "0" THEN : b3 = " " : ENDIF' leading zero blanking
Sertxd (b3,b2,".",b1," Volts") ' 0.1 resolution XXXremove in normal operationXXX
LowBatteryVoltage:
for b22 = 1 to 10 'flash C0 10 times when LVD fault detected
high led2
PAUSE 200
low led2
PAUSE 500
next b22
LVDfaultcount = LVDfaultcount + 1
write 2,WORD LVDfaultcount ' This stores the "LVDfaultcount" in EEPROM location 2
sertxd("LVDfaultcount: ",#LVDfaultcount,13,10)
sertxd("Low Battery (") ' XXXremove in normal operationXXX
gosub ShowVoltage
sertxd(") - Waiting for Voltage to reach 14V",13,10) ' XXXremove in normal operationXXX
pause 4000 ' wait 1 second between readings
loop until Volts >= highbattvolt 'see symbols above was (115)
'// Battery voltage has now reached upper level
sertxd("Battery has reached 14v ")
gosub ShowVoltage
sertxd(" - Now charging for 30 mins",13,10)
'// Now wait an hour while battery continues to charge
'// Total charge time = Combination of ChargeReadInterval & ChargeReadCount
Counter = ChargeReadCount
sertxd("Battery level: ")
gosub ShowVoltage
sertxd(" - Charge time remaing: ",#Counter," Seconds",13,10) 'was cr,lf
pause ChargeReadInterval ' Time between voltage readings while charging
dec Counter
loop while Counter > 0
LowBattCount = 0 ' Reset time count for low battery voltage
Memoryrecall:
FlashCount = stallfaultcount 'Initialise loop counter to number of required flashes
Do Until FlashCount = 0
high 0
pause 5000
low 0
pause 5000
Dec FlashCount
pause 10000
flashcount = LVDfaultcount 'Initialise loop counter to number of required flashes
high 0
pause 5000
low 0
pause 5000
Dec FlashCount
stallfaultcount = 0 'clears counters in ram but not eeprom
write 0, stallfaultcount ' clear counter in eeprom
LVDfaultcount = 0 'clears counters in ram but not eeprom
write 2, LVDfaultcount ' clear counter in eeprom
SetFreq M16
