Got a motor control working with my 28x1 and the L293D driver chip. Quite happy with the low / high direction controls and was very pleased that I could control the speed by PWMing the driver enable pin.
Question – could the pwm 1 (or 2) pin on the picaxe be connected to both the enable pins? The driver data sheet suggests minimal current requirements.
Then I met the problem – cant use a servo in the same program!
I have had a look at the HPWM commands, and to be honest I get lost.
All I want to do is drive two motors, in either direction, with speed control. Both at the same speed unless one is stopped with a low / low command. From as slow as possible, consistant with a good pulling power, to full speed.
What area hould I investigate next.
Russ
Russ
