Model Boat Diesel Engine Noise
#1
I have put together this board to produce diesel engine noise for my model boat. It could be used for model lorries as well.
control is by radio control receiver unit, linked to motor.
I'll post pcb file for those that have the free RS program.
The program file.
picture of circuit board.
picture of finished unit.
excel program.
Produces 'Startup' 'running' & 'shutdown'.
By going into setup mode, the various parameters can be altered to suit the engine.
To enter setup
Press buttons A & B
white led flashes
press B
now in setup mode
select parameter, left dial
select variable, right dial
press A to update
default 4 cyclinder by selecting D&D
6 cylinder E&E
9 cylinder F&F
press A & B together to save and return to running mode.
Any question the please feel free to ask.
TOF
Thanks to A.Pond for help with sounds.
#3
;20x2 diesel sound generator.
#picaxe 20x2
#no_data
#no_table
 'VARIABLE DEFINITIONS
 'CONSTANT DEFINITIONS
 'select variable 0-15
 symbol var01=c.0
 symbol var02=c.1
 symbol var04=c.2
 symbol var08=c.3
 'select parameter
 symbol par01=c.4
 symbol par02=c.5
 symbol par04=c.6
 symbol par08=c.7
 symbol PB1=pinb.0
 symbol PB2=pinb.1
 symbol ledY=b.2	;yellow
 symbol neutral_LED=b.3 'red   neutral LED driven from "pin0" (leg 7) high=ON
 symbol ledW=b.4	;white
 symbol ledG=b.5	;green
 symbol radio=b.6
 symbol tda1052=b.7
 symbol parameter=b0
 symbol variable=b1
 symbol running =b4 'engine running flag (1=running 0=stopped)
 symbol demand=b5 'speed demand input, read from radio b.6
 symbol kount=b6 'general purpose counter
 symbol idle_count=w4 'counts revolutions at idle
 symbol pawse=w5 'time between exhaust pulses: note spelling ("pause"
 symbol p=b12 'exhaust pitch (passed from sound lookup table)
 symbol t=b13 'exhaust duration (passed from sound lookup table)
 symbol cownt=b15 'another general purpose counter
 symbol timeout = b16 'number of revolutions at idle before engine stops
 symbol speed=w9
 symbol cyl_count=b20'number of cylinders in engine
 symbol offset=b21
 symbol ex_pitch=b22
 symbol ex_dur=b23
 symbol shutdown_cyl=b24
 symbol shutdown_tmr=b25
 symbol start_loop=b26
 start_loop=5
 symbol midpoint=w14
 midpoint=290
 symbol tickover=w15
 tickover=18000	'EXPERIMENT WITH THESE VALUES TO CHANGE THE DYNAMICS OF THE ENGINE
 symbol topspeed=b32
 symbol revrange=w17
 symbol stophalt=w18
 symbol rate=w19
 symbol limit=w20
 symbol lo=w22
 symbol hi=w23
 symbol writ=b55
; 6 cylinder default for initial setup
offset=10
midpoint=10
cyl_count=6
ex_pitch=133
ex_dur=3
shutdown_cyl=6
;shutdown_tmr=
start_loop=5
midpoint=295
tickover=18000
topspeed=75
revrange=450
stophalt=30000
rate=3500
timeout=30
start_loop=5
timeout=cyl_count+1
limit=tickover-topspeed
if pb1=1 and pb2=1 then goto int2 ; needed for new chip
read 0,b20,b21,b22,b23,b24,b25,b26,b27,b28,b29,b30,b31,b32,b33,b34,b35,b36,b37,b38,b39,b40,b41
int2:
	sound tda1052,(50,50)
loop until pb1=0 and pb2=0
 '========================= PROGRAM STARTS HERE ================================
 'INITIALISATION
 setfreq m8 'set 8Mhz operation to yield 5uSec resolution
if pb1=1 and pb2=1 then goto setup
 'get throttle demand from receiver at "b.6" and assign it to the variable 'speed'
 pulsin radio,1,speed
 ;midpoint setup variable 7
 lo=midpoint-offset
 hi=midpoint+offset
if speed > lo and speed < hi then high ledy:else:low ledy:endif
	speed=0
	goto skipsped
 if speed>hi then ; forward
 	speed=speed-midpoint;hi
 else	;reverse
 	speed=midpoint-speed;lo-speed
 end if
skipsped:
'guard against over-range
 if speed>120 then
 speed=120
 end if
 'quantise speed into 25 values for lookup table
 speed=speed/4
demand=speed*4
 'MAIN LOOP
 if running=1 then
	 'ENGINE RUNNING
 	'process speed demand value and assign value to 'pawse'
 	pawse=demand*revrange max limit 'set spread of speed, limiting if necessary
 	pawse=tickover-pawse 'numerical sense of pawse is inversely related
	pawse=pawse / 5
	;pawse=pawse-90
	'to speed (see above)
	 'generate a cycle of engine sound
	 for cownt=0 to cyl_count 'for each cylinder in turn
		pause 2
		sound b.7,(ex_pitch,ex_dur) 'make exhaust noise
 		pulsout ledg,pawse 'silence until next cylinder fires
 	next
 	'check if speed demand is IDLE
 	if demand<10 then
 	'ENGINE IDLING
 	high neutral_LED 'LED on
 	idle_count=idle_count+1 'increment idle time-out counter
	'NOT IDLING
 	low neutral_LED 'LED off
 	idle_count=0 'reset idle time-out counter
 	end if
;=========================== STOP =======================================
 'check if engine stop required
 if idle_count>timeout then
 'STOP ENGINE
 for pawse=tickover to stophalt step rate 'gradually slow engine
 for cownt=0 to shutdown_cyl;cyl_count 'for each cylinder in turn
 pause 2
 next cownt
 next pawse
 running=0 'clear "engine is running" flag
 end if
'=================================== START ==============================================
	;debug'ENGINE IS NOT RUNNING
 'but has demand been increased from idle in the meantime?
 if demand>10 then
 'YES - START ENGINE
 for cownt=150 to 25 step -start_loop '25'make primitive engine cranking noise
 	sound b.7,(185,6)
	 sound b.7,(205,3)
	 sound b.7,(235,2) 'some experimentation may be of benefit!
 	sound b.7,(254,2) 'or omit this for-next loop altogether
 pause cownt 'for instant start
 next
 	'but leave this next line in!
 	running=1 'set "engine is running" flag
 		'NO - ENGINE REMAINS STOPPED
 		toggle neutral_LED 'flicker neutral LED to signify stopped
 		pause 80 'sets rate of flicker
 		end if
	 end if
;===============================SETUP=================================
;IN SETUP WHITE LED TOGGLES
setup:
sound tda1052,(20,30,40,50)
toggle ledw
pause 50
	loop while pb1=1 or pb2=0
setup1:
toggle ledw
IF PB1=0 THEN SKIPSETUP
VARIABLE=PINSC AND %00001111
PARAMETER=PINSC AND %11110000
PARAMETER=PARAMETER/16
;debug
; center stick offset 0 to 15 either way
if parameter=0 then
	offset=variable*2
; cylinder
IF PARAMETER=1 THEN
	;ADJUST CYLINDERS 1 TO 9 b14
	CYL_COUNT=variable min 1 max 9
ENDIF
;exhaust pitch 133
IF PARAMETER=2 THEN
	;ADJUST 125 + variable b22
	ex_pitch=variable + 125
ENDIF
;exhaust duration 3
IF PARAMETER=3 THEN
	;ADJUST 1 to 5 b23
	ex_dur=variable min 1 max 15
ENDIF
;shutdown cycle cylinder 1-9
IF PARAMETER=4 THEN
	;ADJUST
	shutdown_cyl=variable min 1 max 15
ENDIF
;shutdown timer
IF PARAMETER=5 THEN
	;time to shutdown b16
	timeout= variable * 5 min 5 max 75
ENDIF
;start loop -5
IF PARAMETER=6 THEN
;ADJUST cranking start b26
	start_loop= variable min 1 max 15
ENDIF
;mid point 270-310
IF PARAMETER=7 THEN
	;ADJUST midpoint, stick to center.
	pulsin radio,1,midpoint
ENDIF
;tickover 18000
IF PARAMETER=8 THEN
	;ADJUST tickover w15
	tickover=variable*1800 min 1800
ENDIF
;topspeed 75
IF PARAMETER=9 THEN
	;ADJUST topspeed b32
	topspeed=variable*15 min 15 max 255
ENDIF
;revrange 450  "A"
IF PARAMETER=10 THEN
	;ADJUST revrange w17
	revrange=variable * 50 min 50
ENDIF
;stophalt 30000 "B"
IF PARAMETER=11 THEN
	;ADJUST stophalt w18
	stophalt = variable * 3000 min 3000
ENDIF
;rate 3500  "C"
IF PARAMETER=12 THEN
	;ADJUST step rate w19
	rate= variable * 350 min 350
ENDIF
; default 4 cylinder "D"
IF PARAMETER=13 and variable=13 THEN
sound tda1052,(20,40,20,40)
;4 cylinder
offset=10
midpoint=10
cyl_count=4
ex_pitch=133
ex_dur=3
shutdown_cyl=4
;shutdown_tmr=
start_loop=5
midpoint=295
tickover=18000
topspeed=75
revrange=450
stophalt=30000
rate=3500
timeout=30
start_loop=5
timeout=cyl_count+1
ENDIF
;  "E"
IF PARAMETER=14 and variable=14 THEN
sound tda1052,(20,50,20,50)
; 6 cylinder
offset=10
midpoint=10
cyl_count=6
ex_pitch=133
ex_dur=3
shutdown_cyl=6
;shutdown_tmr=
start_loop=5
midpoint=295
tickover=18000
topspeed=75
revrange=450
stophalt=30000
rate=3500
timeout=30
start_loop=5
timeout=cyl_count+1
ENDIF
;reset to default  "F"
IF PARAMETER=15 and variable=15 THEN
sound tda1052,(20,60,20,60)
offset=10
midpoint=10
cyl_count=9
ex_pitch=133
ex_dur=3
shutdown_cyl=9
;shutdown_tmr=
start_loop=5
midpoint=295
tickover=18000
topspeed=75
revrange=450
stophalt=30000
rate=3500
timeout=30
start_loop=5
timeout=cyl_count+1
ENDIF
SKIPSETUP:
 pulsin b.6,1,speed
 lo=midpoint-offset
 hi=midpoint+offset
	speed=0
	goto setup2
 else	;reverse
 end if
setup2:
;guard against over-range
 if speed>120 then
 speed=120
 end if
 speed=speed/4
demand=speed*2
 'MAIN LOOP
	 'ENGINE RUNNING
	pawse=pawse / 5
	;pawse=pawse-90
		pause 2
		sound tda1052,(ex_pitch,ex_dur) 'make exhaust noise
 	next
if pb1=1 and pb2=1 then goto exitsetup
goto setup1
exitsetup:
write 0,b20,b21,b22,b23,b24,b25,b26,b27,b28,b29,b30,b31,b32,b33,b34,b35,b36,b37,b38,b39,b40,b41
sound tda1052,(50,40,30,20)
toggle ledw
pause 50
loop while pb1=1 or pb2=1
low ledw
#4
I can't upload excel files, so will post pictures, anyone wanting the excel or PCB files will have to request them.
For an excel file you can change the file extension from .xls to an acceptable extension (from memory .dsn will work and then upload with a note to change the file type extension prior to use.
edmunds
#7
Thank you so much for sharing the project. I have finally come across this goldmine of sorts called Finished Projects :).
I'm very interested to test your project to see if ideas from it could be applied to solve my model truck sound challenges. Can you share the schematics as well, pls? I will make it up from the pcb if need be, but maybe you still have the file around.
Thank you and best regards,
Edmunds
#8
Edmunds
Hi edmunds,
I designed the pcb diect from sketches, which I no longer have.
I have moved onto using a WAV player, can program real engine/exhaust noises, and play back 'start' 'idle' 'slow' 'med' 'fast' 'very fast' 'shutdown' as well as a multitude of sounds.
use a 40x2 to connect and control sounds.
can play multiple sounds at the same time.
google for 'WAV Trigger Player'.
TOF
edmunds
#10
Thank you for the replies, guys, but my problem is size. While a tugboat of decent size has plenty of room for everything, 1:87 model car even if it is a truck is badly limited. The problem with a small enough wav player I tested (based on WTV020SD chip) was that it could not play back files without very noticeable pauses. So an accelerating engine sounds like a series of hiccups :).
The speaker that I can squeeze into the car is kind of small, so the sound quality does not come out great even if the input would be hi-fi. I still have four research directions for this project. Namely, produce pwm sound from non-signed files stored on SPI eeprom, find better and suitable external sound IC/module, program a special microchip or arm or whatever chip for this (I expect to need a couple of hundreds of them over time) and finally find sequences of sound commands, that would achieve the same.
Thanks to your previous work, I now played around with the last one and give the tiny speaker, the result is much closer to what I heard from the WTV020SD player before than I expected. However, a lot more experimentation is needed and there is plenty more I need to learn about digitised and synthesised sound.
Regards,
Edmunds
#12
Hi The Old Fart
thank you for sharing this experience.
Can you provide us with an electronic schematic of this very interesting diesel module?
Thank you.
#13
Hi there is there any further information available for the componet values and there location on the pcb, for the diesel engine sound pcb by the old fart in 2014, any help would be appreciated many thanks , Locoman
