Hello friends! A project that I am undertaking requires a square wave, reasonably fast, anywhere from 700KHz up to 35MHz is prime target range. Preference is for 4-30MHz for the given application. The datasheet on the 08M2 and 18M2+ both specify the maximum frequency as set by the internal oscillator, if I'm not mistaken I think it was 32MHz. In any case all I want to know is if the chips can provide (source) that kind of frequency? Can the 08M2 and 18M2+ provide square waves in this range?
I did not see anything that noting that the clock and output freq were different, so I assume you can provide square waves up to that freq? Thanks again friends for all your help.
