Minimising battery drain on the 40X1
BrendanP
I recollect reading post stating that in order to minimise battery drain it is best practice to tie unused I/O pins high or low via R's.
Is this correct?
If so does it matter which pins are tied which way?
Is there anything else I can do to minimse drain? (I'm familiar with disablebod command.)
kranenborg
For pins that can also be outputs you should use a resistor; without one a programming error could cause a shortcut
/Jurjen
